Help!!!!!!!!!!!!!!!!!!!
Old Feb 20, 2003 | 09:59 PM
madmadrid's Avatar
madmadrid
the tranny's shot its done how does $3000 sound for a new lexus tranny from the lexus dealer and labor. My guy quoted me for that much. Whatcha think?
Old Feb 20, 2003 | 10:04 PM
meZoom!'s Avatar
meZoom!
Super Moderator
um, ooooh.... i got price ranges anywhere from $2000-$3500. I know that I already said that there's a good chance the tranny's shot, but if you have the time, I would like for you to get another opinion. Or at least try to find out the mechanics behind the explanation, "the tranny's shot." why? because $3000 is a lot of money.
hang in there...i was in your EXACT same position just a few weeks ago. I regret selling my ES and haven't really been happy ever since.
Old Feb 20, 2003 | 10:29 PM
tiguy99's Avatar
tiguy99
Hey...buddy your best bet is to purchase an extended warantee from a reputable company, let them know your mileage and then claim your tranny repair two weeks after. Its the difference between 1500.00 and 3000.00. Only with the 1500, you get full coverage on the entire car. Some companies can cover you to 150K. Wish you the best. Keep us posted.
Old Feb 20, 2003 | 11:54 PM
madmadrid's Avatar
madmadrid
do you mean 150k miles cuz mine has 160k? Im gonna get another opinion
Thanks for the support you guys
Old Feb 21, 2003 | 09:45 PM
xsohaib's Avatar
xsohaib
Check out the following links
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
http://cgi.ebay.com/ebaymotors/ws/eB...category=33727
Hope this helps
Sohaib
92 ES300
90 Mercedes 560SEL
00 Grand Vitara Lmtd
99 Escort SE
90 Maxima
90 CRX Si
Old Feb 22, 2003 | 12:03 AM
madmadrid's Avatar
madmadrid
i have a 92 es. is the transmission the same as in the 95-97 models....?
Old Feb 22, 2003 | 09:07 AM
Nabeel's Avatar
Nabeel
I don't think so. I believe the '94-'96 got a new, or at least revised, tranny. Looking through old Lexus brochures, the '94+ tranny is reffered to as ECT-i (i= 'intelligence') while the '92-'93 is just ECT. I'm not sure if the transmissions are interchangable though, I would bet that it could be done with a little work. Have you thought about looking for a 5-speed manual? I remember some of the guys here were getting used manuals for not a lot of money.
Old Feb 22, 2003 | 10:16 AM
skperformance's Avatar
skperformance
the tranny is different as well as the engine yours is a cast iron block
the 1mzfe 94-96 is all aluminum
a cheap alternative to extend the car a bit is to do a fluid change but also clean the filter underneath inside the tranny pan
i had problem
much like yours2 years ago
put the car up got under it and dropped the tranny pan pulled out the filter put it back with new fluid and no problem since but i now it is still slipping a bit but i have learned to drive with the tranny to save it and my pocket by letting up on the gas when it is about to shift
with the car cold it will probably go no where no as the fluid is cold and clogging the filter with clutch debris sludge
the filter is not made to be replaced or even serviced costs about 70 from the dealer which is a cheap investment
i really hope this helps
not a hard fix but is really only a band aid to get you running for a while
hey look at me 2 years later still going strong
it has about 15 bolts to removed the tranny pan plus 1 hex nut to drain the fluid first
you need a new gasket and filter for parts 60 minutes and you should be ok
good luck drop me a line if i can help more
www.deucecom.net buy&sell anything in T.O.
Old Feb 27, 2003 | 05:31 PM
madmadrid's Avatar
madmadrid
Unhappy
Took the tranny apart and we found the problem, a little o ring between gears broke from age and the gears started grinding together and wearing down the metal. $2500 due to a 30 cent o ring, funny how things work out
Old Feb 27, 2003 | 05:49 PM
zexen's Avatar
zexen
heh... well still better to have a mechanic do it... if you don't put somethin together when you put your tranny back together... who knows what could happen...
jdanielca
Feb 12, 2019 08:09 PM
Turboo
May 17, 2009 10:39 PM
boosted1
Jul 25, 2008 07:34 AM
JYOO
Feb 22, 2002 09:25 PM
