Vacuum Line Broken... question
Old Mar 16, 2014 | 02:29 PM
clintbw's Avatar
clintbw
Default Vacuum Line Broken... question
I noticed that the vacuum line that connects directly to the vacuum switching valve on my airbox has broken (plastic piece broke into hose, hose disconnected)... I ordered a new valve and as it stands, it's disconnected. What effect would this have on the car? I know the hose connects directly to the charcoal canister. My car is currently experiencing other issues but I was curious what a disconnected line would cause? It's circled in the yellow/orange circle...
Thanks
Old Mar 16, 2014 | 03:52 PM
IzzyB's Avatar
IzzyB
Pretty sure the charcoal can catches unburned fuel vapors. As long as you can start the car it shouldn't be a big deal, except those gases will be released under your hood into a hot engine. I'm not exactly sure, but that doesn't exactly sound good, flammable gas + extreme heat. Someone else may have a better answer. Also, depending on your model year you may check over at ToyotaNation. Some of the 300's have the same engine as the same year Camry/Avalon/Solana and that forum is much more active.
Old Mar 16, 2014 | 04:36 PM
clintbw's Avatar
clintbw
Ah, this makes sense. The intake sucks in the unused vapor that's not absorbed by the charcoal and recycles it into the engine... at least that's what I figure. Thanks for the info!
lexuscfour
Sep 22, 2015 08:08 AM
Albatross
Mar 28, 2014 01:01 PM
Lexus082
May 31, 2012 11:23 AM
keskipper
Sep 16, 2010 07:50 PM
sc3dreamz
Dec 11, 2006 10:11 PM
