PCV Valve Hose
Old Sep 16, 2010 | 06:26 PM
keskipper's Avatar
keskipper
Default PCV Valve Hose
Looking for some feedback...I changed the PCV valve as it is a quick/cheap thing to do...when I took the old one off, the grommet broke (it was obviously old and hardened - the PCV valve didn't look exactly fresh either, so I guess it was a good thing to do!) -- luckily I was able to get it out.
Anyways, when I installed the new grommet and PCV valve, the hose connecting to the top of the PCV was very hard and the stock metal wire clip did not have enough pressure to seal it, so I put a screw tightening clamp on it to stop the vacuum leak.
My question is, should the hose be pliable and rubbery, or is it supposed to be hard like that? All the other hoses around it were pliable but this one...
Thanks in advance...
Old Sep 16, 2010 | 06:28 PM
xx69xx's Avatar
xx69xx
Should be relativley flexible but they dry out and crack over time and become stiff.
Old Sep 16, 2010 | 07:32 PM
StiCk3's Avatar
StiCk3
you can replace both the hose and the grommet relatively cheaply. shouldn't be more than 5 bucks at a dealership
Old Sep 16, 2010 | 07:50 PM
keskipper's Avatar
keskipper
I replaced the grommet, Autozone had one. Unfortunately there is no Lexus dealer close to me - there is a Toyota dealer about 20 minutes away, will check if they have a new hose...
it is like plastic, not rubber. I have heard that some hoses are designed this way (ones with angles, to keep them from flexing under vacuum if they are curved) but I wasn't sure if this one was. thanks for the info
lexuscfour
Sep 22, 2015 08:08 AM
g1itchgsr
Sep 8, 2015 04:11 PM
lex2001
Feb 6, 2011 08:01 AM
Dx3
Jan 7, 2008 11:03 AM
SCV8
Maintenance
Jan 9, 2003 09:48 PM
