Should I replace the generator?
Old Jan 12, 2014 | 09:37 AM
pirate2050's Avatar
pirate2050
Default Should I replace the generator?(SOLVED)
Hi everyone. I have a 1993 lexus vcv10 car in good work condition and never replace the generator before. Last week I found the battery is low (A little hard to start the engine), so I take down the battery and charged it. Then I put a voltmeter on cigarette lighter socket to monitor the voltage. I find the voltage is 13.9V when cold start, after 10 minute engine running, the voltage is 13.3V. Then I stop the engine ,wait for half hour, then restart it, the voltage is still 13.3V, the voltmeter didn't change even if I step on the accelerater. But if I park the car for several hours, the voltage is always 13.9V on start.
Should I change the generator or check something? Or can I manually adjust the voltage to 14V? Thanks.
Latest update:
I replaced the generator and now the votage is always around 14V and everything is fine. I test the charge current, it is around 2.5A (it is only 0.5A before), is it ok?
Old Jan 12, 2014 | 09:39 AM
PFB's Avatar
PFB
Sounds more like a battery problem to me.
Either way you should have your charging system under load before replacing anything.
How old is your Battery? If your battery is more than 4 years old, you can take a chance and replace it blindly, as it's probably at the end of its life anyways.
Phil
Old Jan 12, 2014 | 11:15 AM
pirate2050's Avatar
pirate2050
Phil
Thanks very much for your reply, my battery is 2 years old. The battery seems ok after charge, now it is work fine for a week The only issue is the lower voltage when engine hot. I notice if the engine speed is under 750RPM, the voltage is lower than 12.5V at night(with all the light turning on), and I can hear noise in generator sometimes. So I think maybe the generator is too old to supply so much power for all equipment :-)
Old Jan 12, 2014 | 11:37 AM
PFB's Avatar
PFB
You should still spend a few dollars checking your charging system before spending any money on a new Alternator.
Also check the alternator belts to make sure its not loose, worn out, or slipping.
Old Jan 13, 2014 | 05:01 AM
pirate2050's Avatar
pirate2050
Thanks a lot. I asked the local 4S of lexus in China, there'e no repairman know how to checking the charging system on such an old car .I will continue monitor the voltage, seems not a big problem.
Old Jan 13, 2014 | 04:53 PM
Hayk's Avatar
Hayk
Now you really got problems
Old Jan 13, 2014 | 05:00 PM
PFB's Avatar
PFB
Any decent garage, even in China should be equipped to check the charging system of any car. So I'm a bit surprised by what you said.
By the way, I was in China a few months go. Amazing country. Amazing people.
Phil
Old Jan 15, 2014 | 08:53 AM
pirate2050's Avatar
pirate2050
Phil
Glad you like here In fact the 4s told me that there's nothing wrong with my car(with out any test), 13.3V is enough to charge the battery, but I mesured the current by ammeter, it shows the charge current is only 500mA when the votage is 13.3V. I think I should replace the battery first for it is 2 years old.
Old Jan 15, 2014 | 08:55 AM
pirate2050's Avatar
pirate2050
Wow, your car is excellent! I love the white lexus es300.
Old Jan 19, 2014 | 03:56 AM
pirate2050's Avatar
pirate2050
Old Jan 19, 2014 | 11:15 AM
PFB's Avatar
PFB
I'm still not convinced that there was something wrong with your alternator, but it looks like all is ok now.
The amount of amps that an alternator puts out varies with how much is needed to keep the battery charged, as well as how much current your car uses at any one time. So the number of amps will vary from almost 0 amps to 70 amps. it's not a fixed number. What's more important is the battery voltage.
Phil
GregoryNP
Sep 10, 2017 04:35 PM
Parsa
Mar 3, 2016 04:09 PM
Lohus
Sep 23, 2011 08:12 AM
mc7eln
RX - 1st Gen (1999-2003)
Feb 5, 2007 07:53 PM
GOLDSc300
Maintenance
Sep 9, 2003 12:30 PM
