trunk open button not working
98 es 300, the button on the dash will not open the trunk, neither will the keyless flob, the button for the fuel door does work(same fuse) button in glove box pushed in. any ideas what to check. I unplugged wire connector at the latch, checked for voltage, nothing when button pushed. or should I check amps?
For me it stopped working, the wires along the hinge have deteriorated. I have a mechanic who reconnected them together for $50. My trunk light and license plates lights stopped working as well and fixing the wires fixed these problems as well.
There is a trunk button cancel switch in the glove box. Have you checked that yet?
EDIT:
Just realized that you've already tried the button in glove box.
EDIT:
look under the drivers side hinge, see the plastic enclosed wires? remove the plastic, also black tape, 3 of my wires were completely broke, the trunk latch wires are red and blue, both were broke, also a green was broke, when fixed both my trunk lite and lic plate lite now work. since there is no slack in the wires I used a 6 in jumper wire and female connectors to reattach the wires.
@PoxLi
Don't believe that belongs in this forum, however, you might want to start by removing all the lining on the trunk and removing the plastic around the lock mechanism and see if that reveals anything. Can't say I'm too familiar with this type of thing, but thats where I would start. You'll need to remove the yellow handle, it probably comes apart in two pieces, then you'll probably have a fastener in the surrounding plastic trim. As well, there will be fasteners all around the lining of the trunk, but they should be pretty easy to see. Then if there are any screws or fasteners that hold the plastic around the lock mechanism will be revealed. Maybe take a picture once you've done that? I'd start with that.
Revived
May 25, 2016 01:11 PM
