2005 e330 power window problem
Old Aug 10, 2013 | 09:54 AM
jamesare's Avatar
jamesare
Unhappy 2005 e330 power window problem
Replaced right rear passenger window motor & regulator. Now when you try to close the window, it goes up to the closed position and returns to the fully open position. Sometimes you can get the window to close, if you just bump the switch numerous times until it gets to the closed position
Thanks in advance for any help
Travel safe
Old Aug 11, 2013 | 03:31 PM
KLF's Avatar
KLF
It sounds to me like the pinch detection switch is out of adjustment. If the switch detects an obstruction while the window is going up, it stops and goes back down. It has to be there if the window can do the "auto up" feature. Complicated system, which is why Lexus puts it on all their windows but the Toyota model will typically only have it on the driver's window.
Not sure how to fix that.
Old Aug 12, 2013 | 12:52 PM
jamesare's Avatar
jamesare
Any idea the location of the pinch detection switch?
simplecar
RX - 1st Gen (1999-2003)
Sep 15, 2018 07:43 PM
bcorreia
Jun 23, 2010 09:34 PM
dr.300
Feb 19, 2010 02:39 AM
jim662
Nov 9, 2009 10:56 PM
lowkeySC
Dec 26, 2008 10:49 AM
