Remote Key problem
Old Jan 10, 2003 | 07:17 PM
yov6cam's Avatar
yov6cam
Default Remote Key problem
I have a 92 ES300 with built in keylock. Recently I ahven't been able to get it to function unles the key is physically touching a metal art of the car itself. I chnged the batteries and used two different keys. Could it have anything to do with the recent battery change?
Old Jan 10, 2003 | 11:48 PM
jaymode's Avatar
jaymode
maybe the antenna is badd on the reciever unit of the car or the transponder in the key is not working properly either.
Old Jan 11, 2003 | 01:19 AM
yov6cam's Avatar
yov6cam
antenna on car?
Old Jan 11, 2003 | 02:38 AM
DevilDog's Avatar
DevilDog
Here is a quick check you can do to see if the key is infact transmitting a signal.
1. Insert key in ignition and turn to accessory
2. Turn on and tune radio to 94.9FM
3. Press the transmit button on the key
4. If the key is sending a signal you will hear interference in the radio. If you don't, the key is bad. If you have already replaced the battery, the key transmitter is probably bad.
God Luck, let us know what happened.
DD
Old Jan 11, 2003 | 12:55 PM
yov6cam's Avatar
yov6cam
I'm gonna try that, what I also meant what I did change the battery in the key, even used the spare key, same result, I have to physically touch the car. What I meant to say was that I changed the car's battery too, another factor could be that I do use an RF modulated cd changer. Anwyays, I am gonna see if the transponders working. Thanks.
Old Jan 13, 2003 | 01:41 AM
yov6cam's Avatar
yov6cam
I checked the 94.9 and I do hear interference. What's more is that if I physically touch the antenna or go near it with remote, it works. I also have to mention that my antenna is malfunctioning because it won't go down, bu the motor still works. It seems that my signal is not strong enough unless I am conducting with the car physically.
awesomefar
May 12, 2018 04:19 PM
aristoboyy
Feb 8, 2016 10:35 PM
ZAM
RC - 1st Gen (2015-present)
20
Jul 10, 2015 09:18 PM
alvinklee
Jan 25, 2015 05:56 PM
lexi06
Jun 26, 2006 10:08 PM
