Gear shifting
Old Jul 9, 2013 | 11:17 AM
ibuddler's Avatar
ibuddler
Default Gear shifting
'97 at 145k
My car idles at 1500 on start (in both summer and winter). If the temperature is below the lowest mark, it won't shift to gear 3 when the engine RPM is below 3k. (Not problem to shift from 1 to 2 at 2k RPM.)
When the temperature goes above the lowest mark, everything goes back to normal. I.e. it can shift to any gears at approximate 2k and idle at 800.
Is there a problem or it's a normal? Also I normally drive the car below 2K RPM. (80% of the time.) Is it good or I need to hit it harder like 3K to shift the gear?
Old Jul 9, 2013 | 12:48 PM
PFB's Avatar
PFB
It's normal.
Old Jul 9, 2013 | 03:25 PM
msekanha's Avatar
msekanha
Mine does the same thing. I believe it's an intended programming by toyota.
Old Jul 10, 2013 | 09:18 AM
ibuddler's Avatar
ibuddler
Thank you guys. Because I saw my friends driving all other cars and none of them have this weird shifting behavior.
In order not to make the engine running at 3K from the start, I have to drive on the 2rd gear and drive at 20MPH for like 1-2 miles. It's kind of annoying when there are cars behind you and everyone will pass me with a dirty look...
Old Jul 10, 2013 | 08:26 PM
Hayk's Avatar
Hayk
Hahaha, there is no harm done at 3k RPM, just give it a little more gas to shift up.
alcan
Jan 30, 2017 07:11 PM
alcan
Jan 30, 2017 05:14 PM
Dajushi
RX - 3rd Gen (2010-2015)
Jun 11, 2015 10:39 PM
Stevelocs
IS - 1st Gen (2001-2005)
Feb 10, 2011 01:20 PM
Vi-Tuyen
Jul 5, 2010 09:40 AM
