Projector Retro?
Old May 3, 2013 | 07:53 AM
DplanDman8's Avatar
DplanDman8
Question Projector Retro?
Ok ive been looking on here for a DIY on retro fitting some projectors in my 2001 es and i find a few threads on people that have done it but nothing on step by step
I was wondering if anyone could tell me step by step on how to do it?
Also everything i need like tools to what projector and what size to get to fit the H7 bulb if anyone can help that would be great because i know it can be done a lot of yall have done it.
Old May 3, 2013 | 09:48 AM
Hayk's Avatar
Hayk
There is a great step by step video on YouTube. The guy retrofitted Morimoto projectors to his Honda Accord, but our cars are identical in the process.
1. Remove the headlight
2. Bake it in an oven
3. Split it apart
4. Remove the halogen assembly
5. Install the projector, tighten it with a lock nut
6. Reseal and align the light
Complete kits are found on TheRetrofitSource. Look for MiniH1 kit for the H7 bulb.
Old May 3, 2013 | 02:54 PM
charley240's Avatar
charley240
Go to hidplanet. I currently have e30 sc430 in mine, but plan on rx330 e30 custom shield. Do your research.
Charley
Old May 3, 2013 | 03:59 PM
Hayk's Avatar
Hayk
I believe this is the guy.
http://www.hidplanet.com/forums/show...gt-2004-Accord
Old May 3, 2013 | 11:41 PM
EEngineer's Avatar
EEngineer
the morimotos are popular but the projector itself is not the greatest.
the most important part of a retrofit is first to make sure you are aligning them correctly.
second is the parts quality.
some of my favourite projectors are the TSX ones, Lexus LS ones and MB E55 projectors.
the after market ones generally have a limited angle of light spread
Old May 4, 2013 | 07:43 AM
5ltrbeater's Avatar
5ltrbeater
3. Split it apart
wait wait wait...so let me get this straight : in step four you just "remove" the halogen assembly? theres no cutting or hacking away at the headlight to make the projector fit?
Old May 4, 2013 | 07:50 AM
EEngineer's Avatar
EEngineer
^ of course there is lol
you'll need a very good dremel kit
Old May 4, 2013 | 08:58 PM
Hayk's Avatar
Hayk
No cutting is needed if you use the Morimoto MiniH1's, that's why they're so popular. If you go with higher end OE components, such as the TSX/RX/LS/MB projectors, you will need to cut the housing.
This is the kit that you need, just make sure to select the H7 Wire Harness.
http://www.theretrofitsource.com/pro...roducts_id=227
Old May 7, 2013 | 06:14 AM
DplanDman8's Avatar
DplanDman8
Thanks for everyones help. So should i just go with the h1 or should i get the ls or rx projectors? are the h1 that clear and straight of a line? or would it be worth the hassle of cutting the housing to fit the other ones?
Old May 7, 2013 | 09:20 AM
DixonPai's Avatar
DixonPai
Honestly speaking, they are all pretty good, its really up to you, its do you want to put the work in. The H1 has a pretty crisp line. Dont get me wrong, the other 2 projectors are very nice and the line are very crisp and provide a good even amount of lighting.
LS most likely wont fit in the ES at all, RX it will, but trust its a lot of measuring and adjusting, just to get the cut off points to line up.
As some has stated, key thing to having projectors is lining them up correctly. Till this very day, I am still trying to align mines better, but I dont think I can any more cause I really thing the person has an accident that causes the housing to be miss aligned when you install them.
Either way, I would suggest the Mini H1, there quick and pretty good for what they are. I have them in mines, and I can tell you that, the lighting is pretty good, but it was not as wide as my old set, but my old set had a crapier cut off.
Lexallday
Oct 3, 2016 05:51 AM
monkey92
Jan 19, 2013 08:31 PM
TougeSC3
Dec 13, 2011 05:45 PM
johnnybmw1
Aug 3, 2009 12:46 PM
KevinGS
Jan 7, 2006 08:13 AM
