window switch rolls window down, not up
Old Feb 19, 2013 | 03:30 PM
RalfyVA's Avatar
RalfyVA
Default window switch rolls window down, not up
('97 es300)
a couple of passenger window switches are malfunctioning. They will roll the window down, but not up. I can roll the windows up from the driver side master switches. Obviously, the windows move so the motors should be fine. What exactly should i replace and is there any types of tests? Should i replace the switches themselves, is there wiring that goes along with it that could be bad?
Old Feb 19, 2013 | 09:47 PM
download's Avatar
download
My 98 got same problem before, it was the switch issues. The plastic parts wear and tear a bit, so the contact of the switch did not press hard enough.
Replace or clean the contact the switches everything will be fine.
Old Feb 20, 2013 | 12:57 AM
Hayk's Avatar
Hayk
You could also try resetting the memory by disconnecting the battery. I've had something similar happen on other cars. You have to make sure that all the windows are closed when disconnecting the negative terminal.
dr.300
Feb 19, 2010 02:39 AM
edgy
RX - 1st Gen (1999-2003)
Feb 2, 2010 12:00 AM
jim662
Nov 9, 2009 10:56 PM
alselby
Sep 21, 2008 11:41 AM
