1998 Lexus ES300 Vibration Problem
Old Feb 16, 2013 | 08:17 PM
asam123's Avatar
asam123
Default 1998 Lexus ES300 Vibration Problem
Hi. I have a 1998 Lexus ES300. When I drive on the freeway at 60+ MPH for more than 10 minutes the car starts vibrating. When the car come to a stop, it start vibrating like crazy. The car vibrates a bit when in motion too, but it's not very noticeable. Here is a video of it happening:
http://www.youtube.com/watch?v=YAxOH...ature=youtu.be
When I turn off my car and turn on my car it doesn't vibrate, but the moment I start the car again, it vibrates. If I leave the car off for at least 10-15 minutes and then start it, it stops vibrating.
My guess is that it is the idle air control valve, but I'm not too sure. Any suggestions?
Old Feb 16, 2013 | 08:54 PM
Hayk's Avatar
Hayk
I had something similar before I cleaned my IACV, but it wasn't as violent. I even had misfires and a CEL come on. So yeah, go get a can of Carb Cleaner and spray it into the IACV. I also tried to get some gunk out of it, by dipping a piece of paper towel into the opening. It must have worked, because the problem went away.
Old Feb 20, 2013 | 09:55 AM
asam123's Avatar
asam123
I cleaned/replaced my IACV. Then I drove about 50 miles on the freeway and through the mountains. I came to a complete stop and the car didn't vibrate. At the next intersection, light suddenly turned red, so I put a sudden brake. Car still didn't vibrate. Then I stopped at a stop sign. No vibration. At the second stop sign, the car suddenly started vibrating (like before), but 1/2 as violent. I turned the car off for about 3-5 minutes and the vibration went away. Drove 50 miles back on the freeway and came to a stop (no sudden brakes this time) and the car didn't vibrate at all. Do you think it's a problem with my brake pads?
Still better than before, where my car vibrated 10-15 minutes into driving on the freeway and during the drive no matter what.
Old Feb 20, 2013 | 09:57 AM
PFB's Avatar
PFB
Here are 2 free things you can try:
Based on your video and descriptions, a vacuum leak is a real possibility. Check carefully the large snorkel hoses in back of the air filter. They are notorious for developing a crack which opens up and then re-closes under certain engine loads. It's best to remove them and visually them.
Also check your engine/transmission mounts.
Phil
Old Mar 8, 2013 | 09:56 PM
asam123's Avatar
asam123
Phil
Ended up taking it to a mechanic while the car was vibrating. Mechanic said the problem was with the exhaust gas recirculation valve. Got the problem fixed. hopefully the car won't vibrate anymore
Lunchbox9
Jun 23, 2013 06:17 PM
dejanuts
Apr 18, 2010 07:56 PM
ourmethod
28
Dec 19, 2009 06:16 AM
oystrpearl
Dec 29, 2008 12:53 AM
OceanView
Maintenance
24
Aug 13, 2007 12:31 PM
