trunk release button failure
Old May 16, 2012 | 04:27 PM
dbcolli's Avatar
dbcolli
Default trunk release button failure
Anyone know how to enable the trunk release button on the trunk lid ?.The release button on the key fob works fine.
Old May 16, 2012 | 05:08 PM
nevernu's Avatar
nevernu
did you try the main switch in the glove box, it should be on/pushed in . see owners manual p 23 or so
Old May 16, 2012 | 05:18 PM
dbcolli's Avatar
dbcolli
Thanks, I did check the glove box switch. I did not know the button was even there on the trunk lid until I saw a friend open his avalon's trunk by pushing a button. I was happy when I found the hidden button but when I push it nothing happens and I had the key fob in my hand.
Old May 16, 2012 | 05:39 PM
nevernu's Avatar
nevernu
there is a wireless remote customization feature to turn the trunk on/off. I dont know if this is one you can reset yourself or if the dealer needs to o it. ill see if i can find it
Old May 16, 2012 | 06:41 PM
nevernu's Avatar
nevernu
can u confirm that your fob works in SmartAccess mode (ie door opens when u touch door handle with the fob in your pocket)?
Old May 17, 2012 | 03:47 AM
garsarno's Avatar
garsarno
My 2011 does work as described above.
Old May 17, 2012 | 05:03 AM
jagtoes's Avatar
jagtoes
I assume you know you have to have the "key" in your pocket and must hold the button for a few seconds before it will open.
Old May 17, 2012 | 05:54 AM
dbcolli's Avatar
dbcolli
I tried again just now, key in my pocket pushed the button for 10 seconds nothing happend, took the key out of my pocket and pushed the trunk button and it opened. I'm thinking maybe a trip to the dealer is in order.
Old May 17, 2012 | 07:04 AM
Dave Mac's Avatar
Dave Mac
I believe there is a dealer set option to have the trunk button function with either one-touch or two-touch and I think the default may be two-touch. I had mine set for a single touch I believe.
Try both and see if it makes a different. Also try push-and-hold.
Dave Mac
Old May 17, 2012 | 07:53 AM
nevernu's Avatar
nevernu
dbcolli
can u confirm that your key fob works in SmartAccess mode (ie doors opens when u touch door handle with the fob in your pocket)? the reason i ask is that there is a customisation to turn Smart Access on and off, and SmartAccess may also control the trunk lid button (not the key fob button). ie the trunk lid button works when Smart Access is enabled and does not work when SmartAccess is disabled.
Lexus Personalized Settings
8. Access System with Electronic Key
When unlocking the doors:
����Deactivates SmartAccess, only accessible using electronic key unlock button. = Off
����Use SmartAccess (touch door handle) or remote buttons. (Standard)= On
oblivionis
Jul 19, 2024 03:59 PM
markwhit
Nov 27, 2023 02:46 AM
kaotiq
Feb 20, 2022 01:32 PM
jbm622
Nov 16, 2013 11:21 AM
dangy
Sep 18, 2009 05:46 AM
