Headlights Adjustment
Hey,
so yesterday i finally drove outta city at nighttime,highway was dark and must say i couldnt see anything, my headlights (low beams) pointing sooo low, that i have visibility of about 2-3 meters... so i had to use high beams. since most of the time im within a city, i didnt need headlights even at the night time, cuz everythin is bright over here, so i didnt notice that headlights fail big time, its just that ive never adjusted headlights before, so im new to that, any help?
Hey,
There is a little level bubble in each headlight - you can see it from the top. You need to park your car on a level surface and turn the bolt in the back of each headlight, until that little bubble is in the center. I forget which way is up and which way is down, but it shouldn't be too hard to figure out. I believe the bolt is 8 or 10mm.
Actually, you may be right. I haven't dealt with my fog lights since last summer, so I don't remember what they look like. I just don't see the point in adjusting the fog lights since they are not meant to be the primary source of lighting.
