Inconsistent crank/start time
Old Feb 6, 2012 | 08:42 PM
CDN_Drew's Avatar
CDN_Drew
Default Inconsistent crank/start time
So my '08 ES350 is developing a slight issue. Truth be told, it's had this issue for about a year now. I got used to my car turning over immediately when I hit the Start/Stop button. Last winter it started cranking for a few seconds and would then turn over. I chalked it up to the winter weather.
But...it was doing it all this past summer too. Even in warm temperature, and sometimes even after driving the car, going shopping for a few hours and coming back, it'll take up to 5 seconds to turn over. Depending how long I left it and ambient temperature, after a few hours and the 5 second crank, engine temp comes up as 1/4 to 1/3. BUT....if I stop the car and immediately restart, the engine turns over immediately. If I leave it for a short period of time (i.e. less than an hour), it will start immediately.
I should have posted about this sooner probably, but I have no idea what it is.
68,000mi / 109,000 km which should be far from a spark plug replacement, but that's the first thing my mechanic suggested.
I'm open to ideas......thanks.
Old Feb 7, 2012 | 04:56 AM
garsarno's Avatar
garsarno
Had similar issues with my 2007, replaced battery before it needed to be in 11/10 as my mechanic noticed that the start up was a little slow. No issues after that but traded car in this past October for 2011. New owner gets the benefit.
Old Feb 9, 2012 | 06:34 AM
retired's Avatar
retired
Same issue.............Replaced Battery with a 24F battery, resolved the issue...Could have used a 35 battery, but the 24F had a higher cold cranking amp and reserve rating..Hope this helps...........Note, when u replace the battery use the backup battery system that plugs into the under the dash computer connection so you dont lose the memory settings, etc..........
Old Feb 9, 2012 | 06:55 AM
RickC5's Avatar
RickC5
Before I read the other two responses above mine, I said to myself: "Sounds like he needs a new battery."
I guess great minds think alike. Ha-ha.
AJsurf
Maintenance
Aug 9, 2017 05:40 PM
peterls
Jan 26, 2016 01:20 PM
kenEs350
Feb 26, 2015 03:27 PM
MythBuster
Jun 18, 2008 12:00 PM
Xterminate
35
Nov 4, 2007 07:43 AM
