Display lights
Old Oct 13, 2011 | 06:08 PM
mitmaks's Avatar
mitmaks
Default Display lights
I have some lights that went out on console display on our 96ES300. Is there fix for that or where could I find part?
Old Oct 13, 2011 | 06:21 PM
DRACO A5OG's Avatar
DRACO A5OG
You can find them at your FLAPS ( Friendly Local Auto Parts Store ) the only thing is the OEM has a blue rubber film on them to create a whiter light for the cluster.
If swap them, I would recommend swapping them all so the light will be the same color or get the OEM from the dealer, which will cost an arm and a leg.
Just note where the bulbs are out and then remove the cluster.
Old Oct 13, 2011 | 10:03 PM
Lexucan's Avatar
Lexucan
Lexucanafer
Are we talking climate control / stereo display lights or for the instrument gauges?
If you are looking for info about the center stack lights check this thread:
https://www.clublexus.com/forums/es3...t-problem.html
And here is one for the gauge cluster lights:
https://www.clublexus.com/forums/es3...ing-bulbs.html
Hope these help ya.
Old Aug 13, 2012 | 07:11 PM
mitmaks's Avatar
mitmaks
Hope these help ya.
I need to change lights for climate control, all other lights I;ve already fixed *cluster and shift selector light
How do I remove climate control unit, does console have to come out first or where all the bolts at?
Old Aug 14, 2012 | 07:07 PM
Cosanostra's Avatar
Cosanostra
Use the search feature to search for: ES300 remove climate control
There are several good posts including one with pictures on removing the center vent to access the upper stereo/climate control bracket screws.
j stuff
Feb 24, 2008 10:54 PM
Shnerez420
SC400 / 300 Classifieds
Nov 28, 2004 08:05 PM
Shnerez420
Oct 16, 2004 06:42 PM
Lexguy026
Sep 8, 2004 08:34 AM
