Fuel Filter Replacement
Old Jul 15, 2011 | 04:41 AM
turtle54's Avatar
turtle54
Default Fuel Filter Replacement
Would it be necessary to replace the fuel filter to help pass emissions? I don't want to if I don't have to. Thanx. Also how would I know if the fuel vapor canister is bad?
Old Jul 15, 2011 | 06:31 AM
Lexmex's Avatar
Lexmex
You would get a check engine light if you had something related to the fuel vapor canister. The fuel filter is not a necessity to pass emissions. In order to be even an issue, it would have to be really clogged up enough to cause a shortfall in the air/fuel ratio on the fuel side. You would very much know if this occurred (you would likely feel it).
Main issues involving car and emissions testing revolve around the two A/F (air/fuel sensors) and the MAF sensor along with sometimes the IACV. A dirty MAF can throw off the balance and causing some pinging knock. A/F sensors get worn after time, but even then they will throw a code if bad enough.
kpal
RX - 1st Gen (1999-2003)
Jul 27, 2018 03:31 PM
jamestravo
May 19, 2017 10:01 AM
TRDmike
Feb 16, 2010 05:40 PM
archangels
22
May 7, 2008 05:10 PM
MKLEX
Aug 25, 2005 04:41 PM
