Shocks and Struts Question.
So there is this thumping at front when i go over little bumps, the bigger the bump on the road the louder the thump, i recently changed the Cushions on the struts because the original ones disintegrated, but it was no difference, i disconnected the sway bar links on both struts and still thumps.
Could it be that i need new mounts? when i replaced the cushions i looked at the mounts and they look fine but then again i don't know what to look for if they are bad.
Any help, thoughts.
Any help, thoughts.
do a push test. continuously push a corner of your car down with both your arms as hard as u can. if ur suspension is healthy, it should go down about an inch or two.
if it bounces up and down a lot more and continues to bounce if u let go of ur hands, then ur only on ur springs, shocks are gone.
also when ur shocks are gone, and u drive over a bump, have someone look at the wheel from a few meters away and if you can see the wheel hop up and down, then ur shocks are gone.
Choritsu-shi
It would have to be within the drive axles... check both the inner and outer CV joints for shaft endplay or any looseness for that matter. This would also include checking the shafts movement going in and out of the transmission. It would likely be loose outer joints and/or the grease within the boots have been worn down to a liquid.
Choritsu-shi
Hows your alignment? Do you have even tire wear? Take a close look at the control arm bushings. Most of the time, the clunking you are hearing is one or both of the bushings.
D-
D-
Any help, thoughts.
Any help, thoughts.
Ok update........Change the Sway bar cushions and still thumping, then i replaced all 4 sway bar links you know from sway bar to strut........and
YAAAAAYYYYYYYYYY thumping gone.
Thank you all for your input and help.
I found these from the same seller what u think?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
The only thing I question is the quality are they as good as the originals or did they feel and look cheaper???
