Blinking AC Light
Old Jun 23, 2011 | 05:21 AM
sharkman63's Avatar
sharkman63
Smile Blinking AC Light
Hey Guys, I want to replace my magnetic clutch relay fuse in an atttempt to correct my AC issue based upon some recommendation from this forum. I am totally inept when it come to mechnical problem solving. I've located the fuse and tried to remove it but I'm simply afraid to really try because I do not want to make things worst than what they are. Can someone please tell me what is the best way to remove this fuse?
Old Jul 1, 2011 | 05:45 PM
bdub03's Avatar
bdub03
Welcome to the board. I've been a member for years and technically don't own a Lexus but have several in the family. The Blinking AC light is caused by the AC RPM Sensor / speed sensor not getting a reading from the compressor. To confirm, if you turn on your AC, the compressor clutch will engage (click) and begin to blow cold air. After 3-4 seconds, it will disengage and the light will blink as it is not receiving a signal from the sensor.
Check the harness on the front of the compressor. I'd unplug and re-plug it back in. If that doesn't fix your issue... Take a look at the following article:
http://www.motor.com/magazine/pdfs/062002_08.pdf
Sensor is located on the bottom of the compressor (must be removed to replace) which means you must evac and re-fill the AC system.
I wish you luck!
Old Jul 1, 2011 | 05:47 PM
bdub03's Avatar
bdub03
Also this...
http://share.qclt.com/丰田Toyota%20RAV...m)/0420050.pdf (best to copy/paste)
Old Jul 1, 2011 | 10:48 PM
LEXTEK1's Avatar
LEXTEK1
Replace the magnetic clutch relay. In the fuse box under the hood. Don't be scared and it wont shock you. It's white and about 70 bucks from your Lexus dealer.
Old Jul 7, 2011 | 08:43 AM
Henrygliss's Avatar
Henrygliss
You can buy used on e-bay for$ 10-$20
Bryant817
Jun 18, 2018 08:04 PM
Bob99b5
Sep 7, 2015 10:04 AM
lostape45
Aug 16, 2014 02:25 PM
dallison
Jan 17, 2008 04:59 PM
D.K.
Maintenance
Jul 28, 2004 02:02 PM
