Flashing AC Light
Old Jun 17, 2018 | 01:17 PM
Bryant817's Avatar
Bryant817
Exclamation Flashing AC Light
2006 Gs 300 when I press my Ac to turn on the light will come on for 2-3 seconds and than starts flashing and its not blowing out cold air.
I'm here in Dallas Texas and I really need to get it fix. I know theres Freon in the car but I've been searching and havent found anything on flashing AC light for 3rd gen GS 300.
Old Jun 17, 2018 | 08:46 PM
guzzy92fs's Avatar
guzzy92fs
Chances areaone of your compressor sensors is faulty or thet AC relay is out, check the relay at the fuse box. Try to connect a scanner and pull a code, most common for faulty sensor is B1451
Old Jun 18, 2018 | 07:15 PM
Bryant817's Avatar
Bryant817
Thank you I will get a hold of a scanner and try to see if I can pull any codes. You also said it could be a compressor sensor is there a way to check that or fix it?
Old Jun 18, 2018 | 08:04 PM
guzzy92fs's Avatar
guzzy92fs
Do you hear the compressor kicking in when you turn the AC on?
If my memory doesn't betray me that flashing indicates that there's a difference between the engine speed and the compressor speed, I used to have a RX that everytime I passed through a high water puddle the belt slipped and throwed me that flashing, it turned off the compressor to protect the system, long story short after digging it turned
​​ out my belt was almost gone.
Have you checked the quality of your serpentine? Also the sensor that I was telling you, is the speed sensor, it can also throw that alert as well or a malfunction inside the compressor, better check it because if the compressor got stuck you will end up with a serpentine out In the middle of the road. Not good..
I would suggest taking the car to an AC shop and make them check the refrigerant level, using the gauges you can also rule out a bad compressor I understand a 100/100 reading indicates that it's not engaging.
Keep us posted!!
sharkman63
Jul 7, 2011 08:43 AM
Dirty SC
Feb 26, 2010 10:00 AM
kathleenkmh
Aug 2, 2003 11:36 PM
