which engines will work?
Old Feb 11, 2011 | 10:17 PM
CoryMiller's Avatar
CoryMiller
Default which engines will work?
so I am in the market for a new engine for my 2000 lexus es300. I have heard that around 2002, the avalon switched to a plastic intake? Will my intake off my current 3.0 vvt-i v6 swap out? What model of cars use the engine in my 2000 es300, i fail at google search
Old Feb 12, 2011 | 01:12 PM
CoryMiller's Avatar
CoryMiller
seriously? no one?
Old Feb 12, 2011 | 01:21 PM
RXGS's Avatar
RXGS
I believe it does, but don't quote me on that. If you don't mind me asking, what happened to the engine you have?
Old Feb 12, 2011 | 01:27 PM
CoryMiller's Avatar
CoryMiller
burns oil like crazy, didn't wanna replace valve seals, and have the heads redone....engine sludge killed my engine. Whoever owned it before me, drove it 97,xxx miles between oil changes
Old Feb 13, 2011 | 03:50 PM
CoryMiller's Avatar
CoryMiller
50 views...only one reply. pitiful
Old Feb 13, 2011 | 04:05 PM
01ES300NYC's Avatar
01ES300NYC
The 1MZ-FE with VVT-i is used in the Avalon, Highlander, Sienna and Camry. Output is 210 hp (156 kW) at 5800 rpm with 222 ft·lbf (328 N·m) of torque at 4400 rpm. Early versions of the VVT-i 1MZ used a dual throttle body, cast aluminum intake manifold, and EGR block off plates on the exhaust manifolds. Later versions used an ABS plastic intake manifold to further weight reduction and decrease cost. These versions may also have drive-by-wire/electronic throttle control.
Applications:
1999–2003 Lexus RX 300 (US market)
1999–2003 Lexus ES 300
2000–2004 Toyota Avalon
2001–2003 Toyota Highlander/Kluger
2001–2003 Toyota Sienna
2002– Toyota Alphard (Japanese domestic market)
2003–2006 Toyota Camry (V6)
Old Feb 13, 2011 | 05:14 PM
CoryMiller's Avatar
CoryMiller
thank you! now one last question, can the intake manifold off an older 1mz be used in place of the plastic intake manifold of the newer 1mz? Thank you sir for your assistance
Old Feb 13, 2011 | 06:13 PM
01ES300NYC's Avatar
01ES300NYC
I'm not sure... sorry
valeoray
Jun 2, 2019 01:28 PM
vgbu56
Jan 19, 2018 06:26 PM
VanCityLS4
Mar 16, 2017 03:55 AM
joelex
Sep 10, 2010 08:03 AM
CPerez100
15
May 12, 2003 02:41 PM
