3ES Check Engine Light
Old Sep 1, 2010 | 05:41 PM
DixonPai's Avatar
DixonPai
Exclamation 3ES Check Engine Light
Alright, have not been really active lately here, but there is something wrong with her. So one day the check engine light came on, so I was like lets reset ECU to see if it come back on, it did not, until after like 400 miles or less miles, my check engine lite came back on. But I have noticed a problem with my es for a while now, I did not think much of it, but I should have. When my car idles at times, when it drops below that tick right below the 1K tick, my car will try to rev it self to get it back up to that tick (the needle will go up and down not a lot but go above the tick and below it), and my car will shake and feel like I am in a manual rocking forward and backward. If I can I will get video so it explains itself better. do you guys have any idea or anyone had this issue? I ordered an OBDII reader, so waiting till it comes in, and I will see what codes come up.
Old Sep 1, 2010 | 07:00 PM
Rollin'ES3's Avatar
Rollin'ES3
CL Folding 10,000
From the sounds of it. I am leaning towards the Idle Control Valve. Cause I had the same idling issue and just needed to clean that out. But I did not have a check engine light with that problem so that makes me a bit worried.. Instructions here to clean that out (all free no need for parts)...
http://us.lexusownersclub.com/forums...howtopic=30723
But it would be best to scan the car and see what is going on. Hopefully nothing major.
Old Sep 4, 2010 | 09:39 AM
DixonPai's Avatar
DixonPai
Alright I'll give that a try, yea still waiting for my obdII reader, but man i really hope its nothing big
Old Sep 13, 2010 | 05:33 PM
DixonPai's Avatar
DixonPai
LOL i came out with a reading P0402 (Exhaust Gas Recirculation Flow (EGR) Excessive Detected)
Causes
A code P0402 most likely means one or more of the following has happened:
* The DPFE (differential pressure) sensor is faulty and needs to be replaced
* There is a blockage in the EGR (most likely carbon buildup)
* The EGR valve is faulty
* The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions
With a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
* Check the voltage at the DPFE sensor both at idle and when the EGR is open
* Replace the DPFE sensor
So now what? would cleaning idle control valve help it? and i guess i can seafoam, since i need oil change also
Ladoo1980
IS - 1st Gen (2001-2005)
Apr 23, 2017 10:28 AM
dangt84
Feb 18, 2012 10:15 AM
Alexusoftime
Performance
May 18, 2010 04:37 PM
dma251
Mar 20, 2010 12:51 PM
b1ackhawk
Feb 6, 2006 10:56 PM
