Amp power source to trunk 1996
Old Feb 22, 2010 | 01:12 PM
adreano17's Avatar
adreano17
Unhappy Amp power source to trunk 1996
Has anyone installed a amp and subwoofer in the trunk? I cannot find a void in the firewall so i can run the power cord through the inside. Who has had success? and to run signal and power cords through the car, usually people just pop off running boards. I tried that today, and there is no space to do so, and the carpet is stapled down so I cant go under it. Pictures would be much appreciated
Old Feb 22, 2010 | 01:21 PM
ASG14's Avatar
ASG14
Drivers side engine bay, between the strut tower and the firewall,there should be stock wires goign through it. Run it with those into the fender and then into the car through the rubber boot.
Old Feb 22, 2010 | 01:31 PM
adreano17's Avatar
adreano17
pictures? i have no clue lol. and how about running it through the car too
Old Feb 22, 2010 | 07:37 PM
HamBurglar's Avatar
HamBurglar
There is a small space or hole near the pedals you can run some power and remote wires through.
Lift up the carpet after you pull the plastic panels off along the edges of the door holding the carpet down.
Run power on one side of your car and RCAs on the other side or you'll get some strange winding sound like I did years ago.
Pull the back seat out or atleast the back part of the seat and theres a space in the corner to run the rest of the wires to the trunk.
After you pull some of the headlining stuff from the trunk down to expose the metal, sand down some paint and drill a hole for ground or unbolt an existing bolt and sand down some paint and run your ground wires on it.
Good luck!
Old Feb 23, 2010 | 08:11 AM
adreano17's Avatar
adreano17
Good luck!
where will it come out in the engine bay?
Old Feb 23, 2010 | 09:43 AM
adreano17's Avatar
adreano17
ok, i see the stock wires in the bay, but it looks like a tight fit and i dont know if the power cord will fit through it. and the rubber boot of the shock or what?
flyc2c
May 14, 2019 12:39 PM
Carcus
Feb 17, 2019 02:54 PM
Matt2Sharp
Aug 18, 2009 04:38 PM
llcoolpass
14
Apr 7, 2008 06:57 PM
daddykay24
Sep 28, 2005 12:14 PM
