CD Player Install Idea
Old Jun 9, 2009 | 09:26 PM
Will3038's Avatar
Will3038
Lightbulb CD Player Install Idea
Hi, im new to fourm and had a question. I was wondering if it is possible to install a (Jensen - 40W x 4 AppleŽ iPodŽ/XM Satellite Radio-Ready DVD Deck with Built-In HD Radio and 7" Monitor) where my front cup holder is, and how to do it. oh btw I own a 93 es300
Old Jun 10, 2009 | 12:16 AM
12340987's Avatar
12340987
You would be better off putting it in where the OEM head unit is. They make custom fit installer kits for just $16. Look for metra 8150.
If that's not possible I'd say you'd be the first to replace the cupholder with XM. You'd probably regret that later...
Old Jun 10, 2009 | 12:31 AM
Will3038's Avatar
Will3038
Yea ill probably order that and do it thanks. what could/shld i put under it. Is there anywhere i can buy the wood dash and cut out an area for it
Old Jun 10, 2009 | 12:36 AM
12340987's Avatar
12340987
They come with a cubbie so there aren't any gaping holes anywhere. That DVD LCD deck is only single DIN?
Old Jun 10, 2009 | 12:51 AM
Will3038's Avatar
Will3038
yea single that folds back into cdplayer. should i just go with the pioneer that goes in double din
Old Jun 10, 2009 | 02:16 AM
faithless's Avatar
faithless
There are kits running around from $15-$40. You can find single din with a pocket or double din. I got a single din with a pocket from a company called sonix electroincs that I'm using with an alpine deck. Only issue I have found is over some bumps with mine the top willcome out about 1/2in or so.
Old Jun 11, 2009 | 07:39 PM
Will3038's Avatar
Will3038
hmm is it possible to attach a ps2 to these too
Old Jun 11, 2009 | 07:48 PM
12340987's Avatar
12340987
Anything is possible with money, because with enough money you can buy more time, as is my understanding.
With a cigarette lighter socket power inverter, and a LCD deck with video inputs you could do it pretty cheap though. I think most of those decks have inputs so you should be set. I would go single DIN so you have a place for your mp3 player. Although double DIN decks I'm sure have loads more features.
PS2 slims only draw 45 watts too, so you could conceivably run the thing for hours until the battery died.
Old Jun 13, 2009 | 05:11 AM
kphu's Avatar
kphu
With time and money anything can be done. Here's something that one of the other members did to his car. Pretty sick and will give you some ideas.
https://www.clublexus.com/forums/lex...c-install.html
Good luck!
charlie@jd
GX - 1st Gen (2003-2009)
37
Jan 5, 2013 03:30 PM
reddlexus
May 4, 2006 03:19 PM
mjr24
Apr 2, 2002 10:33 AM
