XM Tuner Install
Old May 20, 2009 | 03:31 PM
StlGasMan's Avatar
StlGasMan
Originally Posted by bhaubold
I ended up mounting the antenna to the right side of the brake light on the rear deck. Leaving enough room to clean the rear window. I glued a piece of velcro to the antenna and it held very well to the deck material.
How did you push the antenna cable into the trunk. It keeps getting caught? What did you with the 3" wide rubber piece with double stick tape?
Old May 22, 2009 | 04:41 AM
StlGasMan's Avatar
StlGasMan
I'll answer my own question. I removed the housing from the antenna cable connector and was able to feed the wire.
Old Jun 20, 2009 | 11:13 AM
ITB's Avatar
ITB
Hello - I would like to order the tuner. Can someone provide the model number? This is the one I'm looking at: Lexus GS350 OEM XM SATELLITE RADIO TUNER 86120-AA150, for my 2009 ES350. Is this it? Thanks!
Old Jun 20, 2009 | 09:39 PM
StlGasMan's Avatar
StlGasMan
Does anybody have the reception drop out with just a little tree cover?
Old Jun 28, 2009 | 05:15 AM
Richie7's Avatar
Richie7
I recently added an XM radio to myt 09 ES350. I bought it on ebay from Park Place Lexus in Grapevine, TX for about $269 plus shipping. They were very good to work with via emails and prompt shipping. It took a little over an hour to install and you do NOT have to disconnect the battery. It is all plug and clip in addition to screwing your tuner into the trunk where there is a place for it on the passenger side. The model number they sent me was #86100-0W190. The radio came from the Lexus dealer but is a Toyota radio. I am sure it also fits the Camry's. Love it and I put the antenna inside the rear window next to the brake light. No regrets. Works fine. Good luck.
Old Jun 28, 2009 | 05:18 AM
Richie7's Avatar
Richie7
Default XM Radio Tuner Model Number
Richie
Old Jul 1, 2009 | 07:25 PM
StlGasMan's Avatar
StlGasMan
Richie
How is your reception?
Old Jul 11, 2009 | 11:16 AM
Akachan LS's Avatar
Akachan LS
I just installed the factory XM kit in my ES. Everything went great except for one problem. Sometimes the system will sound as if it is loosing the signal and then the sound will completely dissappear. The radio indicator will still read all the pertinent information, ie: The artist, song title and station, but the sound will die out, and the only way to get it back is to turn the engine off and then turn the car back on.
Anyone else here with the same problem? Any help would be greatly appreaciated.
Old Jul 12, 2009 | 04:38 AM
garsarno's Avatar
garsarno
This has always been one of my big gripes about the ES350: this should have the satellite radio system integrated into the Lexus sound system, ready to use like the Big Three and not have the owners scrambling around to get it installed aftermarket and experiencing reception issues. Same with remote starting systems.
Old Jul 17, 2009 | 09:04 AM
StlGasMan's Avatar
StlGasMan
The only problem I have is that the signal is lost easily (minimal tree cover) but it comes right back.
Old Jul 18, 2009 | 09:21 PM
Akachan LS's Avatar
Akachan LS
Default Problem Solved
I believe the problem has been solved. I replaced the original tuner with a new one and, so far, I have not had the issue to reoccur. Apparently the original tuner was defective.
Old Jul 18, 2009 | 09:25 PM
Akachan LS's Avatar
Akachan LS
I totally agree. The car should have been XM ready from day one, with a better quality XM radio.
Old Jul 19, 2009 | 10:41 AM
StlGasMan's Avatar
StlGasMan
How easily do you lose your signal now?
Old Jul 19, 2009 | 02:12 PM
Akachan LS's Avatar
Akachan LS
I would say that my reception with the new tuner is about the same as the old one, which I would say is quite good. My antenna is mounted on the trunk. There are quite a few trees in my area, that at times, may interfere with the signal. However, with the new tuner, the XM sound does not cut out completely.
rhinnard
Apr 28, 2016 09:12 AM
dlrshort
Dec 5, 2011 06:12 AM
DenverGS
Oct 12, 2009 02:12 PM
is350matic
Nov 12, 2006 01:47 PM
Brian
Mar 2, 2005 05:59 PM
