Engine almost dying out on long drives.....
Has anyone here had this problem before. I have a 92, ES and when I drive the car for long periods of time and or if its a hot day, the car seems like its about to stall, I can see the RPM kinda dip below 1000. There were a few times where it did die out on me. The only way I can try to stop this is putting it in Neutral and then let it sit for a bit if I am at a STOP sign or a RED light. Any suggestions??? Please help.
It seems like its doing that more on hot days, I did put in fuel injector cleaner, but it just seems to be a little better. Is it bad to always use fuel injector cleaner for every fillup? Does this mean it will clean it better? or does it harm my engine. If i use it like 5 times straight with every fillup will it make it cleaner where I can go back to using it for every 5000 miles? Thank you for any inputs.
Have you tried getting a tune up? That is my next step. I'm going to make sure they do everything they can to tune up my car. I heard on the radio that if you have dirty spark plugs or wire connectors, your engine can die out. So try that, its my next step next week.
