Thermostat HELP!
Old Dec 1, 2008 | 07:17 AM
javery74's Avatar
javery74
Default Thermostat HELP!
Long story short. Let my 99 ES300 warm up about 15 minutes and everything seemed normal. I have a 45 mile commute and after about 30 miles I noticed my temp gauge hadn't moved from the cold position even though I still have heat. I believe it's the thermostat. Is this something I can replace myself? Any help/advice would be greatly appreciated.
Thanks!
Old Dec 1, 2008 | 08:12 AM
JSM1284's Avatar
JSM1284
The thermostat would cause on of two conditions, Either overheat, or not enough heat. If the guage never moved, it sounds like a temp sensor problem.
Old Dec 1, 2008 | 08:15 AM
javery74's Avatar
javery74
Is there anyway for me to check or should I just take it to the shop? Thanks for the help!
Old Dec 1, 2008 | 08:37 AM
charley240's Avatar
charley240
yeah, it does sound like a temp sensor problem. because even if you installed the thermostat with the jiggle valve upside down, the engine should warm up a little.
my .02
Charley
Old Dec 1, 2008 | 09:32 AM
JSM1284's Avatar
JSM1284
unplug the temp sender, Check the temp guage, then take a jumper wire and go from the sender plug(the wire connector), and touch it to ground somewhere on the engine, then check guage. If it moved, then the sending unit is bad.
Old Dec 1, 2008 | 10:47 AM
javery74's Avatar
javery74
Thanks! I will check it out tonight!
Old Dec 1, 2008 | 10:55 AM
JSM1284's Avatar
JSM1284
Or if you have a Digital Volt Meter, Check that there is continuity through the sensor. If so, its good. If not, its bad.
Old Dec 3, 2008 | 06:09 AM
javery74's Avatar
javery74
Thanks for all the help and it was the temp sending unit!!!
mgw234
Apr 24, 2013 09:06 PM
mfb496
Dec 13, 2012 02:40 PM
Bigxdaddy
Aug 25, 2011 11:25 PM
vFLOODv
Aug 26, 2010 11:59 PM
JUSROLLIN
Sep 16, 2003 05:51 AM
