Does the mileage computer know...
Old Oct 8, 2008 | 12:57 PM
Tarkio's Avatar
Tarkio
Default Does the mileage computer know...
...if the AC is on or off? Will it compute better mileage (as it should) with the AC off?
Old Oct 10, 2008 | 01:24 PM
AlexusES50's Avatar
AlexusES50
I do not think this holds true...in the past the AC systmes were engine driven using up more fuel however in the newer cars they are battery driven, using the power from the electrical system and not fuel...i would say the fuel consumption is about the same in not exactly the same...
Old Oct 10, 2008 | 04:58 PM
jagtoes's Avatar
jagtoes
I think you need to understand how the AC system works. The compressor is still driven by a belt off of the crankshaft pulley. So the AC will put a load on the engine when it is on which will require more torque . This will burn a little more fuel but the newer AC compressor are more efficent . The mileage CPU does not care if the AC is on or off and will give you a reading based on the the amount of fuel being used. So you will get less MPG with the AC on unless you drive with the windows open. This will cause more drag and use more fuel. So because I don't care about how much fuel I burn I drive with the AC on auto and set at 72*.
Old Oct 10, 2008 | 05:06 PM
ThePhantom's Avatar
ThePhantom
Huh? That's news to me...
AFAIK, there's still an A/C compressor -- which puts a drag on the engine when engaged.
Regardless, the fuel consumption computer doesn't need to "know" about it anyway. The calculation is determined based on consumption and the travel distance of the vehicle -- which is impacted by a number of factors that the computer doesn't need to "know" about. If you're towing something, that calculation should reflect the consumption -- without any input by you. Same thing is you have a trunk full of cinder blocks, etc...
<edit> jagtoes -- you beat me to the same point! So much for posting at the same time
NCLex
16
May 10, 2016 06:51 AM
RX300malib
RX - 1st Gen (1999-2003)
35
Apr 20, 2011 11:20 AM
tuninghaus
Apr 11, 2007 07:35 PM
ttsukamoto
Feb 17, 2007 06:26 PM
sayadil
GX - 1st Gen (2003-2009)
Jul 14, 2006 05:46 PM
