Braking Problem
Old May 18, 2008 | 06:42 PM
Bdub215's Avatar
Bdub215
Question Braking Problem
I have a 95 ES300 that i got a couple weeks ago. while driving it around, i've noticed that as im slowing to a stop the brake pedal feels like it looses pressure for a second then comes back up. the pads are good all around and brake fluid is up to max. where do i start?
Old May 18, 2008 | 11:05 PM
paintrain's Avatar
paintrain
clean the floor in ur garage. drive ur car for the day like normal and then park in the garage. pull it out in the morning and see if anything is leakin by lookin for spots on the floor. other than having a small leak i cant think of anything without actually driving the car for myself
Old May 19, 2008 | 12:35 AM
smokesgtp's Avatar
smokesgtp
Power brake booster is all I can think of if the fluid isn't obviously leaking. At 191k it's feasible. Did you check the the booster hose see if it's squishy or cracked? Don't ask me where it is lol I haven't done anything to the brakes on these cars yet.
Old May 19, 2008 | 03:45 PM
Bdub215's Avatar
Bdub215
the booster hose is good and under the car is clean. would air in the system cause this problem?
Old May 19, 2008 | 04:25 PM
kphu's Avatar
kphu
Air in the lines would be my guess if your not having a leak.
You'll have to bleed the lines. A rule of thumb is start with the wheel that's farthest from the master cylinder.
Old May 19, 2008 | 07:26 PM
llcoolpass's Avatar
llcoolpass
Smile "water" in the caliper
what i suspect is while you probably have some air in your brake hydraulic system, i suspect it is contaminated with water.
first you press brake, it works
then it gets hot
then water boils
the water quickly turns into gas
gas is compressible
pedal goes down a little as gas is compressed
then the pedal works decently again after the gas is compressed
you probably have water getting in the fluid near the calipers. i would flush out the brake fluid really good, especially the calipers. also, once the moisture content gets this high like yours, the caliper tends to rot out from the inside means your piston might freeze up etc.
Old May 24, 2008 | 11:25 AM
Bdub215's Avatar
Bdub215
then it gets hot
then water boils
gas is compressible
i also forgot to mention there's a "clunk" sound that goes along with the brakes
808_GS400
Suspension and Brakes
Oct 9, 2022 08:17 AM
daddiojigg
Jul 20, 2018 09:41 PM
Hadley71
Jul 6, 2018 12:21 PM
bauer26
GX - 1st Gen (2003-2009)
Mar 9, 2013 10:48 AM
qwerty04
Sep 21, 2012 12:16 PM
