Foglights
Old Dec 27, 2007 | 09:19 AM
pjw7790's Avatar
pjw7790
Default Foglights
How do you get to the foglights in a 98 ES300? i need to replace them but i can't for the life of me figure out how to get the assemblies off!!
Thanks in advance.
Old Dec 27, 2007 | 09:27 AM
JSM1284's Avatar
JSM1284
Are you just replacing the bulbs, or the whole light assemblies?
Old Dec 27, 2007 | 09:28 AM
pjw7790's Avatar
pjw7790
just the bulbs
Old Dec 27, 2007 | 09:36 AM
JSM1284's Avatar
JSM1284
Remove the bolts from the lower splash shield under the bumper to get to the back of the fog light, then remove the bulb and put in new one.
Old Dec 27, 2007 | 10:06 AM
charley240's Avatar
charley240
its actually not as easy as it seems. inspect closely and you should be able to figure it out. also search around, if i remember right, there is some info on this.
you turn the bulb cap to loosen/remove it. connected through this cap are the wires to the actualy bulb of the fogs. its a little bulb. but then i believe you should have some clip holding it in place.
goodluck
Charley
btw, since you are putting in a new bulb, you should do the other side as well. not necessary, but should be done.
Old Dec 27, 2007 | 12:29 PM
pjw7790's Avatar
pjw7790
yeah i'm replacing both. i brought my car to my mechanic today for a power steering leak and he said he'd put them on for me. i have a feeling he won't remember so i'm probably still going to need this info. Thank you!
Old Dec 27, 2007 | 07:56 PM
LEX ES300's Avatar
LEX ES300
I have prepared the ULTIMATE GUIDE for changing foglights (with pics) - You don't even have to get under the car!
Check this out:
https://www.clublexus.com/forums/sho...d.php?t=326366
LEX ES300
Old Dec 28, 2007 | 11:29 AM
R1R's Avatar
R1R
Check this out:
LEX ES300
Very nice writeup! I have taken my headlights out lots of times but never thought about changing the fog light bulbs this way.
Doing it from underneath is a major PITA! Those plastic clips are impossible to remove without breaking them. That is the biggest problem underneath.
ManXP
May 16, 2013 07:42 AM
billydpowe
Oct 11, 2010 01:40 PM
FireCode
Aug 28, 2010 05:47 AM
sundaekim
Jan 1, 2002 04:40 AM
