es250??
Old Oct 14, 2007 | 12:53 PM
JFLACO610's Avatar
JFLACO610
Default es250??
any way to get some es250 advice or am i too ol' skool????thanks
Old Oct 14, 2007 | 01:09 PM
Sash's Avatar
Sash
Post up, I am sure someone could help you.
Old Oct 14, 2007 | 02:44 PM
powerwave's Avatar
powerwave
whatcha need?
Old Oct 14, 2007 | 04:27 PM
JFLACO610's Avatar
JFLACO610
Default Smoe Tlc
Jus Got A 91 Es 250 With 115,000k For $600(not Bad) Looks Like Theres Alotta Oil On The Bottom, The Guy Was Honest & Said His Mechanic Said It Needed A Valve Cover Gasket, But The 1 Closest To The Cabin Looks Like A B$!ch To Get To, Otherwise The Car Runs Really Nice, Just Wanna Take Care Of The Oil & Also Need To Know Where I Can Find Some Aftermarket Parts For It, Thanks Fellas
Old Oct 14, 2007 | 04:49 PM
powerwave's Avatar
powerwave
yeah the rear is a PITA... probably needs more than just the vcg though. these engines tend to start pouring oil at some point without seal replacement. ours is the only one hubs (pro toyota mechanic until back injury) has ever seen that did not leak, and that's because ours used to and he fixed it! lol
probably time for timing belt, water pump, crank seal, cam seals... maybe oil pan gasket. check power steering lines, trans pan gasket to start with. rear main might be leaking. check axle seals too.
we used all OEM parts (except some of the bigger stuff- rack and struts) for a reason.
we got ours with 168k, dead engine, for $600 also. at least yours is running good deal for sure. good luck with it!
oh and if you want pics of various states of disassembly in the engine compartment do a search for my es250 threads. i took lots of pics.
Old Oct 14, 2007 | 06:11 PM
TORTOISE's Avatar
TORTOISE
sounnds like a good deal. Low miles too.
Old Oct 14, 2007 | 06:46 PM
sonyman's Avatar
sonyman
Excellent deal for a running car!
Old Oct 14, 2007 | 11:57 PM
JFLACO610's Avatar
JFLACO610
Default crowded
yea, i just got an ls400 too but thats at the mechanics(embarrasing story)so i picked this up, though it smokes alittle when its warmed up in the area of the rear valve cover, its just so crowded i cant tell what it is, but the car is quiet, smooth, etc, the ls is mine & the es is for my g/f & her daughter so i wanna make sure i can prevent as many problems as possible. looks like the oil is mostly middle & right side underneath, from up top it looks like a 16 yr old car, not messy or oily
Old Oct 15, 2007 | 06:46 AM
Choas's Avatar
Choas
CL Folding 10,000
Jflaco610 welcome to CL nice to see an es250 here. I had a es250 when I was 17 still have if for parts now. On to your oil problem if it gets to bad I got a motor for you lol. Also powerwave I never had a problem with any seals or oil with my motor am I just lucky or is it that it has 40k on it?
Old Oct 15, 2007 | 09:45 AM
powerwave's Avatar
powerwave
we've never owned a 2vz-fe with that low miles on it, lol! i'd guess the latter.
iirc the camry had 132k on it when we bought it last year, 140k when it was totalled and we dumped the engine into the es250. it poured oil from the day we bought it.
Old Oct 15, 2007 | 12:49 PM
JFLACO610's Avatar
JFLACO610
Default alotta oil
well from underneath theres clearly alotta oil thats leaked i just cant tell where, it smokes form the area where the rear valve cover is at, but i ran it for 30 minutes & it was ok just keeps smokin(not from the exhaust)just the engine and id like to do it myself but it really looks like a p.i.t.a See with the LS i hade lexls.com which was great but i haven't found nothing similar.
Old Oct 15, 2007 | 01:22 PM
sonyman's Avatar
sonyman
http://techinfo.toyota.com
Old Oct 15, 2007 | 02:42 PM
benny20's Avatar
benny20
Thumbs up
Hi
We also have a ES250g, so any info on repairs or parts that you use would be useful. ours 96 ES250g 87K pearl white & Gold 17" Momo's Thanks
Old Oct 15, 2007 | 03:05 PM
sonyman's Avatar
sonyman
Originally Posted by benny20
Hi
Yours is the newer body style, the VCV10. In the USA, the VCV10 was only offered with a 3.0L V6, whereas in other markets, such as yours apparently, it was offered with a 2.5L V6 as well. Since your ES is a 1996, I'm not sure whether you have a VZ-series engine or an MZ-series engine. See if you can find any markings on it or take a picture. If it's an MZ-series, such as the 2MZ-FE, it's more closely related mechanically to the ES300 than the ES250 being referred to in this thread.
Old Oct 15, 2007 | 03:32 PM
JFLACO610's Avatar
JFLACO610
Default its a 91
its a 91 es250, sorry if i said 96, som1 else said its a 2VZ - FE
