05 ES 330 Maintenance Required reset
Old Sep 22, 2007 | 08:58 PM
GNX6's Avatar
GNX6
Default 05 ES 330 Maintenance Required reset
How can I turn off the Maintenance Required light (maint req) on an 05 ES 330? I reset it on the navigation unit but it still says it on the dash. Now that the free maintenance is up I'll do it myself. No $180 oil change for me! Thanks!
Old Sep 23, 2007 | 05:09 AM
92ES5sp's Avatar
92ES5sp
Smile
Youre mileage display has to be in odometer mode. With the key off, press and hold the SELECT/RESET button. Now turn the key to ON. Youll see the bars running across the screen and the light will turn off.
Old Mar 19, 2008 | 06:57 AM
LexGrl702's Avatar
LexGrl702
hey boys, I know this is an old thread, but I need help on this. It's the first time I have to get the light to go off on my own. Just to clarify the SELECT/RESET button is the little button on the cruise control handle right? And what bars will run across the screen? A bar will show up on the navi screen? Thanks!
Old Mar 19, 2008 | 08:25 AM
JSM1284's Avatar
JSM1284
No, You need to use the trip button on your cluster. Switch it till it says ODO, Turn the key off, Hold the trip button down and turn the key on, once the bars appear (-----), release the trip button.
Old Mar 19, 2008 | 08:28 AM
LexGrl702's Avatar
LexGrl702
ahhh, thanks JSM, I knew I can count on you...I was just waiting patiently. Ok, I will try it on my lunch hour. Thanks!
btw, how's the rebuild going on the es you bought from Texas?
Old Mar 19, 2008 | 10:45 AM
LexGrl702's Avatar
LexGrl702
It worked! At first it didn't cause I turned the engine on, but the second time it was fine. Thanks again JSM.
Old Mar 27, 2011 | 04:11 PM
Mfenimore's Avatar
Mfenimore
A million thanks. Just curious-how do you know it's simply an oil change reminder, and not something actually wrong with the car/engine?
Old Mar 28, 2011 | 12:16 PM
pauloil's Avatar
pauloil
by the appearance of a CEL
Old Mar 28, 2011 | 02:27 PM
KLF's Avatar
KLF
Yup, the Maintenance light is nothing more, just an annoying reminder to bring it to the dealer and get out your credit card. If something is wrong, then the Check Engine light comes on.
Old Mar 29, 2011 | 07:06 AM
Mfenimore's Avatar
Mfenimore
Thanks guys! As a first-time Lexus owner for about a month now it is a good feeling to have such a wealth of available knowledge at my fingertips. I was worried that light was going to cost me $...
Old Apr 2, 2011 | 05:40 PM
snowmaker's Avatar
snowmaker
The manual in the car covers this..It is a royal PITA..
Bubble
Aug 31, 2015 07:43 PM
diplomacyk
Nov 7, 2011 07:22 AM
bigolow
Jun 23, 2011 07:04 PM
gs4bkny
Nov 29, 2010 06:30 PM
amnstjohn
Dec 20, 2007 12:19 AM
