help!! lug nut stuck, need spare
As i pulled into a parking space front of my apartment a big flat screw just jams into my tire. because of rust I cant get the lug nuts off my aftermarket wheel. is it safe to use wd40 to loosen the nut? if not veggie oil??
just to make sure turn LEFT is to loose the nut, and RIGHT to tighten it right??
any help is greatly appreciated
yup, go ahead and use some WD40.......let it wick into the threads and start to loosen the lug nut. I have found that if you alternate between loosening and trying to tighten the lug, it will break free.......
Now, there is a chance that the lug is "cross-threaded" and stuck. If this is the case, then when trying to loosen th elugnut, you will end up breaking it off and will need to replace the stem bolt.
Good Luck!
Good Luck!
wow with the help of water and veggie oil it took a total of 2 hours just to get the rusted lugs and spacer off (the rusted spacer was harder to get off than all 5 lugs)!! never had/thought a flat is that much of a pain in the ***
i do rotate my tires frequently, like every 3k at least. in FL it rains so frequently that rust can build up in a matter of days. also its very hard to turn a lug nut with rust using a wrench by hand, compared to the shop they use pressurized tools. I just dont feel comfortable soaking my chrome lug nuts in a chemical..........
riverfour
Jun 27, 2016 11:56 AM
ashtray
Wheels, Tires & Brakes Forum
Aug 7, 2012 10:27 AM
