92 es300 problem
Old Aug 11, 2007 | 10:02 PM
itgrowsind's Avatar
itgrowsind
Default 92 es300 problem
I was trying to enjoy a cruise to my local beach when my break light on the dash came on and the brakes almost felt like they had gone out. Bearly able to stop I was able to make it home now I have to wait until Monday to see what itll be. My ? is who knows what this is or has gone through this before
Old Aug 11, 2007 | 10:46 PM
esucaris1's Avatar
esucaris1
check your fluid it might just be low... however if your that low on fluid you should check for leaks at the calipers, and master cylinder, and you might just have worn pads... I would check the entire brake system
Old Aug 12, 2007 | 10:56 AM
itgrowsind's Avatar
itgrowsind
What type of brake fluid should I put in my car?
Old Aug 12, 2007 | 10:58 AM
esucaris1's Avatar
esucaris1
dot 3 brake fluid
Old Aug 12, 2007 | 11:06 AM
itgrowsind's Avatar
itgrowsind
Thank You!
Old Aug 12, 2007 | 02:50 PM
itgrowsind's Avatar
itgrowsind
I filled up the reservoir and the brake light on the engine cluster turned off but brakes still feel like their out. I checked and I can still see some life left on the pads, what could be the problem
Old Aug 12, 2007 | 03:23 PM
92ES5sp's Avatar
92ES5sp
Smile
There must be a leak somewhere letting air in the system.
Old Aug 12, 2007 | 03:58 PM
Pheonix's Avatar
Pheonix
Cool
when you let the brake fluid run out you sucked air into the system. you'll have to bleed the system to get rid of all the air. might aswell do it until nothing but fresh fluid is left.
dot 3 or dot 4.
Old Aug 12, 2007 | 06:48 PM
itgrowsind's Avatar
itgrowsind
Anyone got DIY w/ pictures on the bleeding the brake system for a 92' es300?
Old Aug 12, 2007 | 07:22 PM
ivory98es3's Avatar
ivory98es3
Always bleed the farthest caliper first from the master cylinder (i.e. right rear) and work your way around the car.
Old Aug 12, 2007 | 09:33 PM
esucaris1's Avatar
esucaris1
Start the car and have sombody pump the brakes several times and hold the pedal down and then you open the bleeder on the passenger rear caliper then close the bleeder before the pedal is let up... I always have who is helping me call out "DOWN" so I know when to open the bleeder and I call out "UP" so they know when to let up on the pedal... repeat until bubbles stop make sure the fluid in the master is full... keep checking the fluid level!!! move to the drivers side rear caliper and so on until you end up at the drivers side front...
Old Aug 13, 2007 | 03:47 PM
CtrFwd's Avatar
CtrFwd
just curious, Does a car have to be started to bleed a brake line?
Old Aug 13, 2007 | 09:10 PM
esucaris1's Avatar
esucaris1
no it does not have to be started it just makes pushing the pedal easier
Scott610
IS F (2008-2014)
Aug 1, 2017 12:13 PM
Way2FLY
May 16, 2011 06:54 AM
avascon1
Jan 8, 2011 12:19 AM
breakb
Maintenance
Feb 17, 2009 06:42 AM
SLVRGS
GS - 1st Gen (1993-1997)
Nov 26, 2003 06:53 AM
