UL owners
Quick question, does your sunroof one touch close? It states that it is one touch open/close but mine does not close and the dealership did not have an answer for me.
I know that the sunroof will not open from the fob when you open all the windows, so I figured there might be some other options not fully available.
Let me know.
Let me know.
Do you mean that when you tap the button once, it will open; but when you tap it once again, it does not close all the way?
Also, the sunroof should open (with a slight delay) along with the windows if you press and hold the unlock button on the key fob.
Let me know.
Let me know.
If you have the Panoramic Glass Moonroof the answer is no. It'll close about halfway, then you have to press the button a second time to complete the closing. The reason is for safety, because the glass doesn't use sensors to stop it if an object is in the way. The standard moonroof has sensors so there's no need to press this type twice.
Only the standard roof models do.
