Brake system issue
Old Dec 11, 2006 | 12:15 PM
3rdelement's Avatar
3rdelement
Default Brake system issue
ok so my brake pedal isnt firm anymore. i had the brakes blead and still it goes to the floor. So i switched out the master cylander and it was better but still went to the floor very easily. And once stopped the vehicle would slowly start creeping forward. so i thought somewhere i had missed a bubble in the system, took it to my trusted shop and they blead the lines. it was a little better but now its the same problem. Im thinking i got a bad master cylander. anyone have an idea?
Old Dec 14, 2006 | 10:01 AM
lex pilot's Avatar
lex pilot
If it's the same with a new master cylinder odds are it is something else.
Not sure on the system, but there may be a check valve in the ABS pump that is letting fluid by. If it has a piece of dirt under it you may clear it by activating the ABS. Find some ice or snow (should be easy in CO) make it skid a while and the pulsing should blow any crap from under a check valve.
Old Dec 14, 2006 | 10:15 AM
3rdelement's Avatar
3rdelement
well it was the master cylander. brakes are solid now. took a couple sessions of bleeding to get it perfect but im happy with it. thanks for the idea though.
Old Dec 14, 2006 | 12:56 PM
Pheonix's Avatar
Pheonix
Cool
Yay! If you want race car brakes (I don't) you could always try swapping in an MR2 master cylinder & vacuum assist too. Their pedal isn't as progressive as ours.
Old Dec 14, 2006 | 01:04 PM
3rdelement's Avatar
3rdelement
i just like having a firm pedal.
so lets see
highlander Alernator
mr2 limited slip diff
mr2 master cylander with vac assist
front strut bar from solara
hms09
Jan 29, 2014 06:19 PM
89supra884
Oct 5, 2012 02:32 PM
iRyan
Feb 5, 2012 07:08 PM
Sup2jzgte
Jun 5, 2008 11:52 PM
Lexs400
Maintenance
Jan 3, 2006 11:10 AM
