headlights dull when break lights come on????
Old Sep 3, 2006 | 09:17 PM
LAMF's Avatar
LAMF
Default headlights dull when break lights come on????
My headlights dull when i hit the brake, im assuming because the break lights go on. the car also didnt make any noise at all trying to turn it on 3 times in a row then i waited literally 2 seconds and it started right up, and when i turn the headlights on the dash lights dull also(which might be normal but its my first lexus so i dont know)
anybody have the similar issue and any solutions?
Old Sep 3, 2006 | 09:40 PM
ssmoked's Avatar
ssmoked
battery replacement maybe? do you have a system that draws high output? my car does dim the headlights whenever i use any electronic gadgets in the car while the amp is on
Old Sep 3, 2006 | 09:41 PM
ssmoked's Avatar
ssmoked
oh yeah this might be off topic, does ur screen name mean what i think it means? (lame a$$ *****?
Old Sep 4, 2006 | 09:24 AM
Tammy's Avatar
Tammy
My I recommend you have the battery and charging system checked.
I would suspect the alternator having a problem charging your battery. A poor body ground connection or the battery connection itself.
Old Sep 5, 2006 | 10:13 AM
Pogo's Avatar
Pogo
I simply cleaned the battery terminals and the ground wire connections, and the dimming problem disappeared. I still had the battery checked twice – it had perfect readings so I know it and the alternator are fine.
Old Sep 5, 2006 | 12:31 PM
Pheonix's Avatar
Pheonix
Cool
Check the battery, check the alt. Upgrade the big 3 wires in the car.
blacksedan
Apr 18, 2011 11:18 AM
WindFactoR
RX - 1st Gen (1999-2003)
Jan 10, 2006 10:47 PM
Racerhoze
Sep 18, 2004 11:47 AM
JenzLEX
Lighting
Mar 28, 2004 10:06 PM
