99 Memory Seat failure
NEVERMIND (none of the previous owners had ever used it (they said it didnt work) all I had to do was read the manual and program them... whoops.
Sorry it took so long to get back, but yes I am aware of that. Is there something I am maybe missing? I don't see this as a common problem. But if anyone else knows why the memory function is not operating, I would really like to know. Thanks.
I just found this, too (no replies to his message)
http://www.automotiveforums.com/t691...rols_dead.html
Same here no beeps and the fuses are fine. The power adjustments work great however as i read they are run by the same mini computer (not on the technical terms for some car electronics) the wires and everything obvious seems fine. I'm stumped.
Well, I found out that when you un-hook the battery, it resets the memory so it might seem like it isnt working, when infact it just needs to be reprogrammed (in my case this worked). I think you have to hold down the set button and either 1 or 2 then after the beep, set the seat (read the owner's manual)....
Register your Lexus here, and they'll send you an Owners Manual, free!!
https://owners.lexus.com/lexusowners...egistration.do
VroomSC430
Dec 28, 2025 12:59 PM
