foglight mod- different scenario.
Old Mar 2, 2006 | 08:46 PM
papachino's Avatar
papachino
Default foglight mod- different scenario.
I did the foglight mod with some help from this thread https://www.clublexus.com/forums/sho...d.php?t=145544. But I only achieved half I was hoping for . I really wanted be able to run all three lights at the same time (my fogs always turned off on with brights) and since the foglights aren't on the same circuit as the headlights, they don't turn off when I leave the car anymore, a compromise I can deal with. I was hoping if someone can help me find a solution and also let me know what fuse I used to hardwire the setup. I have some pics to follow. My setup is different because it is a 93 Es and the thread was meant for a 97'-01'. I not sure if he encountered the same problems. aw look, you can see my baby celebrity and my seadoo to the side of the car, memories
Old Mar 2, 2006 | 08:48 PM
papachino's Avatar
papachino
This is the yellow 20 amp fuse that I used to provide power into the relay. I just stuck the wire into the slot. The black wire leads into the relay. The tape just secures the relay in place.
Old Mar 2, 2006 | 08:50 PM
papachino's Avatar
papachino
Also it would be nice to know what this is, it is to the bottom left of the steering wheel and I took the cover off so that you can get a look at it.
Old Mar 2, 2006 | 11:42 PM
Pheonix's Avatar
Pheonix
Cool
Doesn't matter what year you have. It's still voltage from the low/high beam powering the stock relay that trips with the fog light switch. All you have to do is find a small, constant 12v supply of voltage to run your relay with. There are a bunch of them.
That is the wiper relay the best I can remember. IDK Download the factory service manual for a '93 ES 300.
Old Mar 3, 2006 | 05:30 PM
papachino's Avatar
papachino
where do you get the factory service manual?
AndyWSU
Oct 24, 2013 02:06 PM
dpham528
Dec 14, 2011 12:16 PM
LouieV
GS - 1st Gen (1993-1997)
20
Dec 22, 2008 09:23 PM
sjlex
Aug 2, 2008 11:58 AM
MrSypher
Aug 13, 2002 08:14 PM
