error code P0420 and O2 sensor question
Old Dec 18, 2005 | 12:50 PM
allerton's Avatar
allerton
Default error code P0420 and O2 sensor question
My 98' ES300 Got the P0420 agin and agin. Before blame the converter,
I'd like to try those O2's. My question is:
Could the O2 sensor still be bad enven if the resistance reading is in
the correct range?
I checked the resistance, they were correct. My es300 has 110k miles on it.
Dont know if the O2's have been replaced or not by the pre owner.
Old Dec 18, 2005 | 01:49 PM
koolaidman's Avatar
koolaidman
the correct range?
lol u dont check resistance. u check volage output
Old Dec 18, 2005 | 02:03 PM
Eclipsed's Avatar
Eclipsed
The Voltage should read somewhere around .45v after the sensor gets over 600 degrees celcuis. The P0420 code means the catalyst systems efficency is below the standard threshold. It could mean your converter is not performaning to the factory spec, or you also could have a short in the circuit. Get your voltage for the back o2 sensor after letting the car run for a couple minutes to make sure the o2 sensor is over 600 degrees celcuis, then get the recording, if it seems normal, you probably need a new converter.
Old Dec 18, 2005 | 02:26 PM
koolaidman's Avatar
koolaidman
also should be close to a flatline too
Old Dec 18, 2005 | 03:28 PM
Eclipsed's Avatar
Eclipsed
Depends, ussally the wave forms should switch from lean to rich lean to rich, and if the cat is working properly, the waveforms will be the same but it will switch from lean to rich waay slower in the rear o2 sensor then the one in the front.
ameer90
May 13, 2019 06:56 AM
mitmaks
Sep 26, 2013 08:57 PM
grillzrho
Apr 24, 2013 09:16 PM
nicos1
Nov 5, 2007 05:47 PM
beavis1
Maintenance
Oct 17, 2003 03:38 PM
