ES330/300 DIY (do-it-yourself) & technical tips
Old Mar 3, 2016 | 07:04 PM
  #166
lex831's Avatar
lex831
very useful thanks
Old Mar 10, 2016 | 04:52 PM
  #167
Malformed's Avatar
Malformed
How To: Change Rear Wheel Hub Bearing Assembly on an ES300 (97 - 01)
Old Aug 19, 2016 | 11:56 AM
  #168
Bluescreen's Avatar
Bluescreen
ES330 (and others) detailed Mark Levinson woofer fix with rubber cement (post #8):
https://www.clublexus.com/forums/es-...oofer-fix.html
Old May 4, 2017 | 08:11 PM
  #169
kimtalbot's Avatar
kimtalbot
Hi, any idea about headlight adjustment on ES300 (2003), please
Old Jul 29, 2017 | 02:37 AM
  #170
Leo123's Avatar
Leo123
Làm thế nào để tháo gạt tàn giữa một chiếc ES '97 -'01 ES
Old Sep 23, 2017 | 09:17 AM
  #171
TimV's Avatar
TimV
Default Es330 disp button steering wheel 2005 not working.
Originally Posted by lexusk8
I decided to place this thread for the purpose of making common issues and methods readily available for all ES owners. These include often-discussed topics like "How do I clear the headlights?" and "Where can I get the instrument cluster lights fixed?". This will NOT include debatable topics like "Can 20's fit in my ES?" or "Will a K&N air filter be OK for my ES?". Remember that as far as this thread is concerned, we are looking for factual answers, and nothing opinionated.
When posting in this thread, please include a brief description of the topic or issue, and a valid URL (it can be CL-related or non-CL related). Only post here if you DO have a topic AND a URL(s) to share.
Hopefully you guys will find this thread useful, and not have to rely on making new threads within the ES forum and asking infinitely repeated questions Don't forget to use the search engine too!
where do I start?
Old Sep 30, 2017 | 09:10 AM
  #172
Ernest78's Avatar
Ernest78
Default Wheel Barrier kit
I want to know do 2001 ES 300 wheel barriering fit a 2003 ES 300?
Old Mar 4, 2018 | 08:53 AM
  #173
finny76's Avatar
finny76
I cant seem to find a DIY for replacing the entire Headlight Assembly (not bulbs)
Old Jun 4, 2018 | 06:16 AM
  #174
JonFES330's Avatar
JonFES330
Exclamation
[QUOTE=3000;1504557]How to get headlights clean
Link is no longer valid; have a new one? Thanks!
Old Jun 4, 2018 | 06:20 AM
  #175
JonFES330's Avatar
JonFES330
Exclamation Cleaning Headlight Covers - Need Link?
Originally Posted by ESeries300
Plastex also works
Link no longer good; have a new one?
Old Sep 27, 2018 | 03:00 PM
  #176
DanoATX's Avatar
DanoATX
When replacing headlight bulbs (ES300), it is easier to remove the entire headlight than to try to replace the bulb while the headlight is in the car. With the removal of a few screws, you can have the entire headlight out within a few minutes of starting. Then you can replace the bulbs on a workbench.
Old Sep 27, 2018 | 04:00 PM
  #177
DanoATX's Avatar
DanoATX
This video is terrible, but you can see enough to get it done.
Old Oct 18, 2018 | 11:00 AM
  #178
CodyHayes's Avatar
CodyHayes
i decided to place this thread for the purpose of making common issues and methods readily available for all es owners. These include often-discussed topics like "how do i clear the headlights?" and "where can i get the instrument cluster lights fixed?". This will not include debatable topics like "can 20's fit in my es?" or "will a k&n air filter be ok for my es?". Remember that as far as this thread is concerned, we are looking for factual answers, and nothing opinionated.
When posting in this thread, please include a brief description of the topic or issue, and a valid url (it can be cl-related or non-cl related). only post here if you do have a topic and a url(s) to share.
hopefully you guys will find this thread useful, and not have to rely on making new threads within the es forum and asking infinitely repeated questions don't forget to use the search engine too!
im new and dont know how to use the forums even after reading the new person stuff. How do i ask questions and where? What do i click on? I dont see any options
Old Jan 18, 2019 | 02:34 PM
  #179
Rolodon's Avatar
Rolodon
Default Oxygen Sensors
Can anyone please tell me how many oxygen sensors are in a 2000 Es300 ? I got a code of P0171 bank 1 . Only sensors I'm finding is the front exhaust manifold by radiator , between the firewall and one by the CC
Old Feb 7, 2019 | 01:57 PM
  #180
Chadman83's Avatar
Chadman83
Ok so it’s just like the Camry, first there’s the one you see front of engine by radiator, then there’s a second in the same position just opposite on the other side of engine, beneath intake manifold, there should be another in the exhaust further down as well. You can pretty much follow the exhaust from head to cat to tail pipe and you’ll see them. Hopefully this helps.
Take note of where Bank 1 and Bank 2 are, then the easy part is sensor 1 or sensor 2
