Audio Issue
Old May 23, 2025 | 06:34 PM
vetdoc's Avatar
vetdoc
Angry Audio Issue
Hi Guys
So I went on a vacation for 3 weeks and plugged a battery tender into my 2013 ES350 U/L with Mark Levenson sound system. When I got back from vacation I took the car out and the radio had no sound and the phone command voice was also without sound. The phone connects successfully to the car but no sound and the radio had no sound ,but the volume displays higher numbers when volume is turned up. I checked the mute control on the dash and its off. So I drove the car and made several stops and after about 2-3 stops and restarting the engine the radio sound turned on and the phone command had voice! The next day on starting up the car audio is out again, but after several stop and starts the radio comes back on as well as phone sound.
I don't know if there is a short somewhere in the system or a loose wire in the Amplifier connectors. I don't think a blown fuse would cause intermittent sound loss and back on again .
I saw there were old posts about similar audio issues with no real explanation or resolution.
What do you guys think about this?
Thanks
Old May 24, 2025 | 09:53 AM
Mhn's Avatar
Mhn
Default Same problem with my 2013.
Originally Posted by vetdoc
Hi Guys
Thanks
Have same problem with my 2013 Mark Levinson system. I pulled all connections from amplifer under drivers seat and reattached them to no avail. I'm pretty sure the amps they used are failing. Called United Radio in New York and was given a quote of 750.00 to rebuild it. I haven't done this yet but am still considering it. You can also look on E-bay as there are a few for sale but high priced. There are no aftermarket units so your kind of stuck. Let me know if you have any luck. My lexus has 63,000 miles on it and is still a very nice car so I'm gonna get it fixed.
Old May 24, 2025 | 10:50 AM
vetdoc's Avatar
vetdoc
Thanks for your response. I have 68000 miles on my ES and its still in very nice condition as well. Let me know if you send the amp off to United Radio and if it fixes the issue, I heard good reviews for them.
Good Luck
Old May 24, 2025 | 12:30 PM
mcomer's Avatar
mcomer
Quick trick that might clear this up. The overhead "SOS" button for the now obsolete Safety Connect will interrupt both the stereo and the BT Phone when it takes over the speakers and microphone.
Try pressing the SOS button, it will speak up with one of a couple of automated responses. None of them matter because the 3G towers that the 2013 would need to connect to are gone. In this case
just press the SOS button again to clear the system. Next to the SOS button are a couple of lights that should now be dark. Is the Red light on or does it come on during this exercise?
Old May 25, 2025 | 03:55 AM
NdYAG's Avatar
NdYAG
My SOS light is always red now - I have assumed it is because there is no more connection. Are you saying it should be off?
Old May 25, 2025 | 05:31 AM
Mhn's Avatar
Mhn
Default SOS button
Thanks for the reply. It was worth trying but to no avail. Still think it's the amplifer.
Old May 25, 2025 | 11:41 AM
larrytstar's Avatar
larrytstar
I have the exact same issue. 2013 ES350 UL with 165K miles. I have owned the car since new and maintained it meticulously. Recently the radio issue as described here has started. I will follow this thread with interest to see if anyone diagnoses and solves the problem. This forum is great.
Old May 25, 2025 | 03:31 PM
vetdoc's Avatar
vetdoc
the SOS symbol is illuminated all the time, The 2 small dot lights to the right of the SOS symbol should be off all the time unless you push the SOS switch
Old May 25, 2025 | 03:55 PM
st1800's Avatar
st1800
Try pushing and holding the volume button, I heard that reboots the system.
Old May 25, 2025 | 04:43 PM
larrytstar's Avatar
larrytstar
st1800: Yes, it does. Unfortunately, it has no impact on this problem.
Old May 27, 2025 | 01:45 PM
mcomer's Avatar
mcomer
The now obsolete SOS Safety Connect system (on 2010 through 2017 Lexus) had two lights flanking the button.
Both should be dark now, left light was solid Green during the trials of various lengths and if subscribed, same light
would be blinking Green when an actual connection was active. The right light was Red and would illuminate when
the specific vehicle had a wiring or component failure. When the 3G towers when away so did all the devices that
were tuned to them. Lexus and others did not make any upfit or refit plans to bridge to the 4G or now 5G systems.
Current new models include the phrase "4G Network Dependent" on the sticker.
Before coming over to Lexus from Chevrolet I had an Impala. When it was out of warrantee it began to drain the
battery very quickly. OK, new battery. No good, turned out to be the On-Star telecommunication module.
Well, let's pull the fuse! Nope, then you will have no stereo. $400 later it was fixed up for a system I was not
subscribed to! %&#$
Old Jun 1, 2025 | 02:42 PM
larrytstar's Avatar
larrytstar
So, I guess there is no easy fix. If any of you find one, please post it. Also, Mhn, please let us know if you send your amp to United Radio and if that works out. Take care guys. Have a good summer.
Old Jun 25, 2025 | 06:36 PM
vetdoc's Avatar
vetdoc
So an update on my audio issue with my Mark Levinson radio problem in my 2013 Es 350 . There is a continuous intermittent problem with the audio working for a few days and then silent until several stop start of the engine and back on again. Yesterday there was a super loud pop-cracking sound from the speakers and radio stopped working. I thought for sure that was it but, today the radio is working again lol.
So I found a reliable repair source that has been repairing Mark Levinson car audio products since 2013, " OEM Audio " repair in Manlius ,NY, They said my issue is most likely the amplifier with the intermittent issue happening. They charge $575 to diagnose and repair the amplifier, that includes shipping both ways. The repair is warrantied for a year. If the amplifier checks out ok then the only charge is the cost to ship it back to you. I'll probably send it to them when I finally get frustrated with increasing intermittent radio failure. They are more reasonable then United Radio and very easy to communicate with the owner of the company.
Old Jun 26, 2025 | 09:09 AM
larrytstar's Avatar
larrytstar
Thanks for the update. Please keep us apprised of how this goes if you do it. I'm in the Boston area but my car is in Puerto Rico. I may try to get this done while I am there after the first of the year. Is it difficult to remove/replace the amp? Also, did he mention the turn-around time? Thx.
Old Jun 26, 2025 | 06:47 PM
vetdoc's Avatar
vetdoc
It's not difficult to remove the amp. It's located under the drivers seat in the 2013 ES. One bolt holds the cover on and then disconnect 2 connectors. The turn around time is about 5-7 days once they receive the amp repair it and send it back.
