Cooling system puzzle!
Hey all,
I recently dumped and filled my 2028 es350 cooling system. Now my guage is rock solid in the center and no overheating or anything .....but. The radiator is completly full as it should be and my reservoir tank is at full all seems fine. My puzzle is that the tank does not vary if hot or cold making me think there is an issued. My understanding and previous observation is that the tank should change level depending on the state of temp.
Scraching head.
And I'm pretty sure there is no air as I did bleed the system the "Car Care Nut" way.
Scraching head.
Richard is your car haunted? I'm sure not so, bur your loosing parts is as bad as mine. Anyway, I had my coolant changed this morning. It only took 1 gal. The mechanic could not find the air relief port that the Care Care Nur was using. So he squeezed the upper hose until no bubbles came out. The temp gage was rock solid on the way home. I checked after a couple of hours and it looked good. I will check in the morning to see if anything is different. In your case, I think that you can keep a close eye on the fluid levels. And act accordingly. If it aint broke, don't fix it.
Ed in the islands
Ed in the islands
So you guys are saying that if you mark your coolant level when car is cold (overnight), and then when you come from a long drive and immediately look at your coolant level its exactly the same as cold? If its exactly the same, it is NOT normal. It supposed to go up and down slightly if your system is completely sealed and has no air. I observed this behavior not only in Toyotas but also Hondas.
when your car cools off at night, open radiator cap in the morning and see if radiator is filled all the way
Thanks, I started this thread thinking I had problems. What I was hoping for is a solution to a problem I can not understand. I point to the fact that the radiator is full and the reservoir is at the full line. Do I need to bleed the system again? Of course you could start thinking a leak in the block somewhere or a head casket. The oil is clear of any signs of water, I get zero coolent smell and the car is running like a top. Pre dump and fill the system as I remember modulated about 1/4 of the over flow tank. You statement of 1/4 inch could be missed just but the state of how level the car is when I check.
