Headlight level sensor -
Old Jun 13, 2023 | 08:08 AM
das1960's Avatar
das1960
Default Headlight level sensor -
The headlight level sensor warning came on and I found this on the rear passenger side of the car. After some thought I asked a friend if he would look at welding it later this week. Any thought as to whether this is a good or bad approach to a repair
Rear Passenger side
Old Jun 13, 2023 | 10:23 AM
Arsenii's Avatar
Arsenii
Hello,
There is usually a good cause for those snapping off, which mostly ends up being the ball joints on the rod connecting the sensor seizing up, I've had that happen before, but since the control arm was toast anyway, I ended up replacing the whole thing. With that, it's not like there are any tremendous loads on the hanger, so if you can do a weld solid enough to support its own weight, you will be good.
Hope this helps and best of luck!
Old Jun 13, 2023 | 12:22 PM
das1960's Avatar
das1960
Thanks, I will check the ball joint Thursday. What I noticed is the break occurred over time. Parts were clearly rusted, just a small bit was shinny metal.
Faridric
May 21, 2023 07:39 AM
lostape45
Apr 2, 2015 12:25 PM
YellowCopy
Dec 7, 2010 01:52 PM
Kostyan
Jan 22, 2010 08:45 AM
ta1972
Sep 11, 2007 09:13 PM
