Trunk lid button.
Old May 10, 2023 | 08:01 PM
Gsx60trim's Avatar
Gsx60trim
5th Gear
Default Trunk lid button.
Anyone experience this?
Old May 11, 2023 | 05:51 AM
spaceballs's Avatar
spaceballs
I have this, it's nasty, the button works fine. Unfortunately it's not possible to buy just the button rubber, you'll need to replace the entire assembly at over $100 (but you can DIY this so you save on labor).
Some people suggested cutting out a bicycle tire inner tube and repurposing that?
Old May 11, 2023 | 10:49 AM
sthpawil's Avatar
sthpawil
It is fairly easy to replace... I changed mine a couple of years ago. Usually cheaper if you use Toyota part number instead of Lexus part number.
https://parts.griecotoyota.com/oem-p...tch-8494550010
Old May 11, 2023 | 11:28 AM
spaceballs's Avatar
spaceballs
I wonder if it's interchangeable with the LS430 part, because for the LS, the button and the cover comes as separate parts, the cover itself is only $10 (84944-50010).
I called my local Toyota parts department and separately the same department under the Lexus brand, both of them quoted me the same price for the part.
Old May 11, 2023 | 12:04 PM
Wilson2000's Avatar
Wilson2000
I used a piece of bicycle inner-tube to make a new rubber seal. I did a pictorial "how-to" and posted it. Search the forum to find it. If you can't find it, let me know and I'll look for it and send the link.
Old May 11, 2023 | 12:45 PM
sthpawil's Avatar
sthpawil
That appears to be correct - good find! Much cheaper than replacing the entire switch.
Old May 11, 2023 | 01:20 PM
ESh's Avatar
ESh
I got it grom Aliexpress for less than $15, OEM.
Old May 11, 2023 | 01:58 PM
spaceballs's Avatar
spaceballs
So I spoke to my local Lexus dealer's parts department and they had 2 comments:
- The part is for the Japanese version of the LS430, not the North American one
- They're not sure if it'll fit but rather "order it and find out"
EDIT: Found a thread where they discuss this, looks like 84944 is a plastic plug part for cars that have no trunk lid switch, and NOT the cover.
Thread in question
Old May 11, 2023 | 06:33 PM
TCoolest2's Avatar
TCoolest2
Guys, everyone is making this complicated. They sell after market ones on amazon for like 20-25 bucks. I had the same issue. Took 10-15 minutes to replace. Once you remove the trunk cover there's two screws and a wire connector. Haven't had any issues. Here it is:
amazon amazon
. I mean sure if you really don't want to spend it and just put another piece of rubber, be my guest.
Yes, like the rest of the fail quality control of Lexus during these years and even further, their rubbers and plastics melting is ridiculous. Mine would melt in warm weather. In colder weather especially winter, it would harden and it would be so difficult to press, the trunk wouldn't open half the time.
Old May 11, 2023 | 10:00 PM
Gsx60trim's Avatar
Gsx60trim
5th Gear
Appreciate all the responses! Ya'll are great.
Old May 12, 2023 | 03:03 PM
Wilson2000's Avatar
Wilson2000
Originally Posted by TCoolest2
Guys, everyone is making this complicated. They sell after market ones on amazon for like 20-25 bucks. I had the same issue. Took 10-15 minutes to replace. Once you remove the trunk cover there's two screws and a wire connector. Haven't had any issues. Here it is: amazon. I mean sure if you really don't want to spend it and just put another piece of rubber, be my guest.
Nice find! This part was not available when I replaced my rubber. Instead, I would have had to replace the whole switch which I found on Amazon for $50. But, my original switch was working fine.
I found the most difficult part of the job was removing all the melted rubber from the switch. It was all gummed up, restricting the free movement of the switch. Removing the fluorescent green handle (inside the trunk) wasn't as easy as I expected either.
Old May 12, 2023 | 10:17 PM
TCoolest2's Avatar
TCoolest2
Thanks! I don't think I actually removed the handle. There's a thread somewhere on this forum where someone shows how to basically just reach in and replace it without removing much. Wasn't too difficult!
Here is a link to the thread. If you scroll down to the post from samathews, they show how to do it without removing the emergency cable, etc.
Link
Old May 13, 2023 | 10:02 AM
Wilson2000's Avatar
Wilson2000
Link
Thanks for the link. I read the post you referenced and it appears the earlier models don't have the flourescent green, internal release handle. Not sure what year this safety device became law, but my 2011 has it.
Old May 13, 2023 | 12:55 PM
ESh's Avatar
ESh
This is what I got:
€ 14,92 26% Off | New REAR TRUNK SWITCH BUTTON For 2007-2012 Lexus ES350 84945-50010
https://a.aliexpress.com/_mrY9rWg
Old Jun 25, 2023 | 02:45 PM
AA2016's Avatar
AA2016
I just replaced mine with OEM part # 84945-50010. I got it from an online Toyota dealer and it was about $70.
After removing the exterior clips, you will encounter two plastic housings that are also clipped to the frame of the trunk. It is best to slide it out of the groove, but you can also carefully pull it so the plastic housing and clip come out as one piece (see pictures for details). You definitely don’t need to remove the trunk release and I used a small 10mm wrench to undo the two screws. After removing it, I used goo gone to clean up the mess around the area. Hopefully this new one doesn’t melt…
