‘06 ES330 Engine Vacuum Diagram
Old Sep 22, 2020 | 11:19 AM
Roqetman's Avatar
Roqetman
Default ‘06 ES330 Engine Vacuum Diagram
Hello, I’m new to the group and have what I hope will be quick and easy question for those of you familiar with the ‘06 ES330 vacuum lines. I recently discovered that apparently someone that did my last oil change at Valvoline did not reconnect the vacuum lines near the air filter. Please see picture. The lines around the 3 in 1 connector were left undone and the nipple on the air filter box is not connected. If possible let me know which line goes where. Amazingly... I have not noticed any issues or warning lights but ... since it’s my wife’s car i don’t want her to have any issues.
Please advise me on correct vacuum line connections.
. Thanks for your help.
Old Sep 22, 2020 | 01:44 PM
Arsenii's Avatar
Arsenii
Hello,
There should be a vacuum diagram sticker attached to the hood. If not, below is the diagram I found for 3MZ engine. Your picture seems a bit confusing, since it appears as the hose nearest to the air box that is attached to the 3 in 1 connector is the one that supposed to go to the air box, and there should be another hose from the other side that goes to that connector. My theory is further supported by the parts diagram that can be found here. Please look for any loose hoses and see where it comes from.
Hope this helps and best of luck!
Old Sep 22, 2020 | 02:32 PM
Oro's Avatar
Oro
Take a look at this thread from last week, see the pic I posted. It's an '02 but I believe there was no change through 2006.
https://www.clublexus.com/forums/es-...piles-are.html
Old Sep 23, 2020 | 05:59 AM
Roqetman's Avatar
Roqetman
Thank you! I will check and compare today!
Old Sep 23, 2020 | 06:00 AM
Roqetman's Avatar
Roqetman
Thank you!
Old Sep 23, 2020 | 12:37 PM
Oro's Avatar
Oro
OK, comparing the pics it looks like someone lost the hose that runs from the T up to the nipple on the post-filter side of the airbox. You can see that in my pic and also trace it in the diagram Arsenii posted. So they just put one of the forward motor mount lines into the T and disabled the motor mount adaptation (because now it has no continuous air supply to the VSV). Exactly what Arsenii said, just different wording. Also, if they left the nipple uncapped, it also allows dirt/contamination into your air intake post-filter.
It looks like if you just get a small section of hose you can re-route everything correctly, and cap off that possible air box leak.
Old Sep 23, 2020 | 02:03 PM
Roqetman's Avatar
Roqetman
Ok, I’ll look for that. Thanks your help!
mastin1
Nov 22, 2024 02:45 PM
richonline
Feb 9, 2014 12:51 PM
Jake88
Oct 3, 2011 01:57 PM
ssmoked
Jul 9, 2008 02:38 PM
hmkim
Sep 15, 2006 08:26 AM
