Engine kept running after switching ignition off
Old Aug 18, 2019 | 06:22 PM
L3xusES3OO's Avatar
L3xusES3OO
Default Engine kept running after switching ignition off
I started the 1999 ES 300 and it started with a weird noise after which I turned the car off. I turn the key to the off position but the engine stayed running with all the accessories even the AC running all the while still making the noise. I turn the key to the start position and the noise stops. I then turn the key to the off position and the engine cuts off. What could’ve possibly happened during the initial start that caused all this?
Old Aug 18, 2019 | 08:19 PM
Does your car have a remote start system installed?
Old Aug 18, 2019 | 08:39 PM
L3xusES3OO's Avatar
L3xusES3OO
No remote start installed. I looked online as to what it could be and it mentioned the remote start problem along with dieseling among other things but my situation doesn’t meet the criteria for those problems.
Old Aug 18, 2019 | 09:07 PM
I don't know what else it could be, back in the old days think cars from the 70's sometimes the ignition switch (the electrical part) would go bad and this would happen don't recall seeing it on an ES. Rodent damage? Water damage?
What do you mean by this
You mean normal sounds you hear with the engine running?
Old Aug 18, 2019 | 09:11 PM
L3xusES3OO's Avatar
L3xusES3OO
The noise that was made upon initially starting the car sounded like a metal on metal faint grinding sound which was audible until I turned the key to start that’s when that noise stopped and I could hear the normal sounds from the engine.
Old Aug 18, 2019 | 09:15 PM
Ah, it could be the starter motor is getting stuck.
Old Aug 18, 2019 | 09:22 PM
Richardsr's Avatar
Richardsr
Did it happen just once?
Old Aug 18, 2019 | 09:23 PM
L3xusES3OO's Avatar
L3xusES3OO
So far it’s only been once I haven’t attempted another start.
Old Aug 21, 2019 | 03:01 PM
L3xusES3OO's Avatar
L3xusES3OO
•••UPDATE•••
Whatever happened didn’t affect the start the following morning or any subsequent day after. Thanks for the replies and let’s continue to “Experience Amazing”
Old Aug 22, 2019 | 09:12 AM
80es300's Avatar
80es300
My experience with Starter (About 120K miles): The contacts wear out and one day the starter plunger got stuck and when I started the car, it turned on but the starter kept on trying to start. It was loud and scary, I immediately disconnected the battery or looked like there would have been fire. Got the contacts changed and all good since then.
Old Aug 22, 2019 | 01:21 PM
Richardsr's Avatar
Richardsr
Originally Posted by L3xusES3OO
•••UPDATE•••
Glad it hasn’t happened again, but it did get me thinking... Some people have the habit of using their car key fob in a way that can have an adverse effect on ignition switches. I can’t recall how many people I’ve seen with dozens of other keys attached and tools and other extraneous BS swinging along. “Weighty” car keys dangling can in fact cause ignition switch failures and/or one-time unexplained failures such as yours. If this is your problem (too much key fob junk), consider reducing the clutter to car and house keys only and put the other stuff on a separate ring. It will pay off in the long run.
daveLL
Dec 7, 2014 03:10 PM
djrazr
Jan 15, 2012 09:41 PM
jay33
Mar 2, 2010 10:46 AM
triplecore
Sep 2, 2006 07:40 PM
mek88
RX - 1st Gen (1999-2003)
Aug 26, 2004 07:23 PM
