Violent shaking at all speeds
Help! 2004 has violent shaking that began mildly around 70 mph, after continued driving it is now worse and begins around 20 mph. Vsc & trac lights are on, upon visual inspection nothing is obviously broken. It has almost new tires...anyone else had any experience like this??
Read the codes and report back, I bet you have an ABS/Traction Control code set that'll help us pinpoint the problem. Most auto parts store chains should read it for you, or invest in a cheap Bluetooth OBD scanner to use with your phone.
the obd code was p0430. Something about airflow on bank something.... Had the tires rotated and balanced today - that was not the issue, i should also mention the shaking is significantly worse when accelerating, however does not feel like a rough idle from the engine, and also it began after the installatiin of a new starter. The entire air box and filter had to be removed to reach it.
Neil4Speed
Performance & Maintenance
06-23-12 10:30 AM
