Could an oil flush possibly solve an oil sludge problem? 2000 ES300
Old 03-25-13, 05:35 AM
johncoby
johncoby's Avatar
I think my best bet is to take it to a mechanic. It is hard to find a good one, but we did about 3 years ago. I trust him. And yes this is one of the recall cars. We got the notice in 2008 or so but had no problems then. You had to have had the problem and filed by the end of 2008.
But...I am now believing this is something else.
Old 03-25-13, 05:59 AM
johncoby
johncoby's Avatar
I think that is it too. I'm not real happy with them. I think they just threw their hands up and gave up.
Old 03-25-13, 07:34 AM
moonphase
moonphase's Avatar
You would be amazed at how nasty looking the oil comes out when you do an engine flush.
Old 03-25-13, 09:50 AM
pdr
pdr's Avatar
Does the mechanic get paid by lexus for a sludge problem but not for normal wear? Maybe that's part of the diagnosis.
Old 03-25-13, 03:28 PM
KLF
KLF's Avatar
Originally Posted by msekanha
The oil plug should be a 15mm socket.
run some marvels mystery oil in your crankcase for about 50 miles and change the oil.
Actually, it is a 14mm wrench. Toyota/Lexus doesn't use 15mm on anything, because it is not a JIS standard. I've been wrenching on Toyotas for (gulp) almost 30 years and I've never seen a 15mm anything on them. If yours is 15mm, then it's not original.
And I agree on the MMO, I would use that over Seafoam. Change the oil, substitute one quart with a quart of MMO, run it a few heat cycles (long drives), then drain and repeat.
Old 03-26-13, 04:56 AM
BDSL
BDSL's Avatar
Yes, the drain plug is 14mm on all the Toyota's and Lexus's I have worked on.
Just follow the oil dip stick tube and you will know where the oil pan is.....
Old 04-01-13, 05:41 AM
johncoby
johncoby's Avatar
ok an update. cylinders 1 3 5 are misfiring. once the car warms the oil pressure drops and the light comes on. mechanic says it will require major repairs. mojor mounts need replacement. steering fluid leak. and more.
Jamespa
06-30-19 09:00 PM
gtstcactus
32
02-04-14 12:02 PM
beanz744
02-25-09 01:38 PM
Ac93sc
Performance & Maintenance
08-05-07 06:03 PM
Quick Reply: Could an oil flush possibly solve an oil sludge problem? 2000 ES300
