diagnostic code
Old Jul 19, 2007 | 08:28 PM
esucaris1's Avatar
esucaris1
Default diagnostic code
I am getting a diagnostic code 25... I suspect ox sensor but not sure... what is the main ox sensor location??? any help???
Old Jul 19, 2007 | 11:31 PM
92ES5sp's Avatar
92ES5sp
Smile
Ha Haz i had the same code. it ended up being the rear O2 sensor. (Fun) There are no vacuum leaks right? Ignition timing is good? The FSM will tell you the procedure. Jump the TE1 and E1 terminals like youre checking codes. Check the voltage between VF1 (for left bank) or VF2 (for right bank) and E1. With the engine up to temp, rev it up to 2500 and check to see if the guage fluctuates up and down while holding that rpm. If it dosent, the sensor went to O2 sensor heaven.
Old Jul 20, 2007 | 05:53 AM
esucaris1's Avatar
esucaris1
good info thanks I coundnt seem to find that in the fsm
Old Jul 20, 2007 | 05:07 PM
esucaris1's Avatar
esucaris1
Last night I reset the computer by disconecting the battery and the light didnt come back on but I have faith that "my car" will screw up again
Old Jul 20, 2007 | 09:22 PM
92ES5sp's Avatar
92ES5sp
Smile
Well normally those codes take 2 trips for the pcm to set the code. The first time it just "notices" it. The flow chart for that code starts on page EG-376 of the fsm. Is 25 the only code youre getting? Are you familiar w/ diagnostic mode 2? Its really a bummer youre having isuues with your car.
Last edited by 92ES5sp; Jul 20, 2007 at 09:26 PM. Reason: made no sense after reading it ;)
Old Jul 20, 2007 | 10:10 PM
esucaris1's Avatar
esucaris1
so far yes 25 is the only one but I havent checked after I reset comp... I'm waiting for the ck eng light to come back on
Old Jul 20, 2007 | 10:26 PM
92ES5sp's Avatar
92ES5sp
Smile
Im just curious did you swap the exhaust maifolds to your new eng? You might be waiting a while for the light to come on cuz on mine the light only came on few a minutes like twice a week. I have no idea why though i mean i checked the o2's and the left bank one was dead....
If your car is calif emissions you also have a 3rd o2 sensor after the cat
Old Jul 20, 2007 | 10:36 PM
esucaris1's Avatar
esucaris1
Yeah I swapped... It came on and stayed on half the day then I ran the code and reset... Tomorrow I will check the o2 sensors...
Old Jul 22, 2007 | 09:00 PM
92ES5sp's Avatar
92ES5sp
Smile
Were you able to test the o2s?
Old Jul 23, 2007 | 10:03 PM
esucaris1's Avatar
esucaris1
Looks like I have a bad ox sensor
lexus114
RX - 1st Gen (1999-2003)
Jun 28, 2009 06:40 AM
jerryhbr
Apr 10, 2008 12:47 PM
t0ekn3e
Feb 13, 2007 12:42 PM
jmoonan
Maintenance
Dec 7, 2005 07:36 PM
