CT 200h Model (2011-2017)
Illuminated Mirror Switch?
Old Jan 23, 2023 | 10:48 PM
MattRX's Avatar
MattRX
Default Illuminated Mirror Switch?
Is the mirror switch on the CT200h backlit? If so, I'm wondering if it's the arrows as well as the "L" and "R" button. I plan on using one to retrofit into my 2008 RX350 which has no such option.
Thanks!
Old Jan 25, 2023 | 06:45 PM
TobiasSing's Avatar
TobiasSing
I just went out and checked on my 2016, and sure enough, it is backlit by built-in green LEDs. You can see that the switch is built into the panel, but maybe it can be used on your RX350. Hope this helps!
Old Jan 25, 2023 | 11:39 PM
MattRX's Avatar
MattRX
Thank you very much! They're probably the same 1206 SMD chips that they use in all the other switches. If I get around to this, I'll post a DIY here on how to change the LEDs.
Old Jan 26, 2023 | 02:53 PM
nigel821's Avatar
nigel821
Arrow
Definitely do! I have to post up a thread as well changing out green leds to white for the HVAC panel. I need to do the other pieces.
Where are you getting your 1206smd leds from? I ordered about 30 different ones trying to get that "lexus" white color that is in my wife's NX and my RCF. I've narrowed it down to 3 I believe that I have.
-Nigel
Old Jan 26, 2023 | 04:29 PM
MattRX's Avatar
MattRX
I got mine from AliExpress. These ones are a little more “white” than the Lexus ones, maybe they are 5500k and Lexus is using 6500k for a more “blue” appearance?
White aftermarket LEDs I added to the window switch (these were originally green in my 2008 RX350)
Finished result, pure white but still looks gold
2020 RX350 OEM steering wheel lights, these are more blue
Old Apr 25, 2023 | 02:12 PM
MattRX's Avatar
MattRX
Like promised, I would provide an update! Like I thought, these switches use 1206 chips. These come with green chips and they take three chips per assembly while receiving around 2 volts. Here is the polarity:
Note: Polarity is also marked on board as well
Yellow chips (For my Highlander)
White chips (For my RX350)
Old Jun 16, 2023 | 07:30 PM
nigel821's Avatar
nigel821
Changed mine from green to white. Also changed the window control switches to white LEDs with a red LED lock indicator.
-Nigel
Old Jun 17, 2023 | 05:27 PM
MattRX's Avatar
MattRX
That turned out great. Which brand LED chips did you use?
Old Jul 11, 2023 | 04:25 AM
nigel821's Avatar
nigel821
Arrow
Thanks! These were the LEDS used throughout the car for the most part.
IN-S126AT5UW Inolux | Mouser
-Nigel
Old Oct 2, 2023 | 12:41 PM
slowct's Avatar
slowct
mine are lit.
DaveWray
Mar 22, 2021 01:25 AM
AlphaRed
Nov 19, 2020 02:38 AM
Raven01750
Sep 17, 2019 08:18 PM
Johnhav430
Sep 17, 2018 05:50 AM
Lettuce
Sep 27, 2005 12:40 PM
